Help ID LT-1 water pump ports, please
Cruising
I don't have a Corvette per se, but a 1994 Corvette LT-1 powers my '37 Plymouth street rod. I'm trying to get the heater re-plumbed and need to ID the inlet and outlet. Every illustration I have found describes the plumbing as if it were installed in an actual Corvette, so I have found the diagrams confusing.
Here's a picture, and the heater ports have been labeled A and B.
Which is which?
Which is which?
Which is which?
Which is which?
This water LT1 Water Pump Appears to be a 94 Malibu. Not the VETTE.. I"m Telling the Plymouth Society you are running a Chevy Engine.
Hopefully this helps out.
hduff (10-23-2015)
Cruising
I didn't build the car. The engine VIN is definitely Corvette, but the accessories are not. It uses an S-10 power steering pump for example as part of the aftermarket accessory assembly. Had I been able to choose, I would have used an early Red Ram or Firedome Hemi, but the LT-1 has been an excellent performer for over 30,000 miles on road trips.
BTW, I do have a Mopar 360 I plan to put in a Chevy or Ford pickup truck ... just because I can.
https://www.google.com/search?q=1994...svwBnQ#imgrc=_
See if you can find what you need in these pictures. Not the best help but better than nothing. You will have to dig a little.
hduff (10-23-2015)
That pump is definitely not for a 1994 Corvette LT1 engine. I'd guess it's for the LT1 that was used in one of GM's other passenger cars, such as the Impala SS, but that's only a guess. I can't help with which is inlet and which is outlet. But does the heater core in your hotrod really care which direction it flows?
So hurry up and post some pix of that car -- sounds like a sweet ride!
Live well,
SJW
Live well,
SJW
hduff (10-23-2015)
Pro Mechanic
C is the return from radiator
D is output to radiator
As for heater core, I agree that it probably doesn't matter which way the coolant flows through the core, but the pipe size should be an indicator. To ME, it looks like A is the outlet for the heater core since it's on the outlet to the block, and B would be the core return.
EDIT: Here are a few pics that may help:
hduff (10-23-2015)
Cruising
Live well,
SJW
Live well,
SJW
Yes. it does care. There's a cutoff valve on one side that blocks the flow of coolant when the A/C is on. If it's plumbed backwards, the coolant pushes the valve open no matter what.
Here's a link to a photo album.
Two thoughts:
1. Dunk the pump in a bucket of water, with the heater hose ports above the surface, rotate the drive shaft in the correct direction, and see what happens.
2. Is the shut-off valve reversible, in the event that you get it plumbed up backward?
Live well,
SJW
hduff (10-23-2015)
Cruising
SJW
SJW
Pro Mechanic
That's weird...I thought I posted which pipe was for what, in post #6. Oh well.
hduff (10-24-2015)
IN THE FOLLOWING LINK:
http://www.wholesalegmpartsonline.co...rimLevel=25289
Not knowing exactly how the "hot rod" is plumbed this would be a properly plumbed LT pump in a similar system using a closed coolant system. It shows the flow control valve also.
hduff (10-24-2015)
Pro Mechanic
If so, then that would agree with my labeling of the pipes. Hose clamp #8 goes on the "pipe A" in your first/original pic.
hduff (10-24-2015)
Cruising
Thanks, guys. I now have the heater plumbed correctly. It had been plumbed backwards since it was built in May 2001. I also discovered that the fan relay to A/C compressor wiring was done incorrectly such that the compressor running would not cause the radiator fan to run. It's never been a big deal since I don't really used the A/C, but this will make my wife very happy next summer.
After 15 years and 30,000 miles of fun from Florida to Canada, the car is showing some wear and age, but that engine stills runs strong.
