headlight trouble...
Old Aug 26, 2002 | 06:06 PM
AggieOO's Avatar
AggieOO
Default headlight trouble...
one of my headlights no longer rotates. It was stuck "up" for a long time and then the other night decided to close, but won't open.
i heard this is a common problem, is there a somewhat easy fix for this, or is it easier to just take it in and have someone fix it?
Old Aug 26, 2002 | 06:39 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: headlight trouble... (AggieOO)
if you unplug the headlight moter you can operate it manually till you get the problem fixed. if it mysteriously worked the other night you might want to take the moter out & inspect the internals....sounds like a possible bad connection(also could be worn gear)? :confused: good luck! :cheers:
Old Aug 26, 2002 | 08:44 PM
JonM's Avatar
JonM
Wink...WInk...
http://www.corvettemagazine.com/2001...ghts/head1.asp
Old Aug 26, 2002 | 09:35 PM
AggieOO's Avatar
AggieOO
Default Re: headlight trouble... (JonM)
thanks guys!
To headlight trouble...
