1990 Headlight help
Old Nov 10, 2015 | 03:27 PM
stc's Avatar
stc
Default 1990 Headlight help
The headlights will not go all the way up.
On the drivers side the manual **** does not make any difference.
On the passenger side I can raise the light using the manual ****.
The lights do come on fine and the headlights close fine.
Help,
Stephen
Old Nov 10, 2015 | 04:41 PM
antfarmer2's Avatar
antfarmer2
many threads and look at youtube cheap and easy fix
Old Nov 10, 2015 | 08:15 PM
jts90vette's Avatar
jts90vette
2021 C4 of the Year - Unmodified Finalist
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
You need these!
http://www.ecklerscorvette.com/corve...1988-1996.html
Old Nov 11, 2015 | 01:19 AM
Cliff Harris's Avatar
Cliff Harris
Originally Posted by jts90vette
When I click on that link it takes me to www.rickscamaros.com (an Eckler's company).
Just go to AutoZone or similar auto supply vendor and get the same thing. It'll save you the shipping and the wait...
Old Nov 11, 2015 | 03:00 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Look in the HELP department. Part number 74410
Old Nov 11, 2015 | 07:24 AM
shootnstarz's Avatar
shootnstarz
Personally, if I was digging into headlight repair I would not only replace the pucks but the gears and linkage bushings as well, since you're already there.
It will probably cost close to $100 to do both but it will operate like new, if your motors are working as they should.
Good luck, let us know how it turns out. BTW, the videos are priceless in this project.
Rick
Old Nov 12, 2015 | 05:46 PM
73n95's Avatar
73n95
Lots of different stories on headlight motors. The vast majority can be repaired with the little bushings purchased on line, or from the "zone", or Advance. The part number is a Dorco number. They are actually designated for Ford power window motors. They serve the same function. I had to file mine down a bit to get them to fit but they work fine. My gears were fine, just the bushings. This seems to be the case for most headlight repairs. The first one took about 2 hours, the second under 30 minutes.
Old Nov 15, 2015 | 06:30 PM
stc's Avatar
stc
I have ordered some of the bronze gears and new bushings and will be fitting them next week. Hope that fixes the issue!!
Stephen
Old Nov 15, 2015 | 07:02 PM
antfarmer2's Avatar
antfarmer2
Stephen
I would not use any metal gears better to have the cheaper weak link most likely just the pucks.
To 1990 Headlight help
