Got A Problem
Old Nov 13, 2015 | 06:34 AM
aussiec4corvette's Avatar
aussiec4corvette
Cruising
Default Got A Problem
I have just had my brakes done on my 1988 C4... pads were changed... the people doing it had problems putting the new pads on and the handbrake cylinder was difficult as well... got an alignment done also plus wheels balanced...
Anyway after all that I was driving it home and noticed the turn signals weren't working.... never had that problem before...
I then looked at the fuse for the turn signals at it was blown... so I changed it for a new one and it worked again.
A couple of hours later I took the car out for a drive and the turn signals didn't work again so i drove home and checked the fuse... it was OK.
Baffled I fiddled around with the signal stick on the steering column... still didn't work... then turned on the hazzard lights and then things got real interesting... smoke started to come out of the steering column.
I don't know what to do now... it could be the signal and hazzard switch in the steering column gone bad or did the people working on the brakes stuff something up... maybe a ground loose or not connected.
I rang the people who fixed the brakes and they said the problems I now have with the turn singles and hazzard lights have nothing to do with the brakes being fixed... it seems strange that I have never had a problem like this before until I took the car to them.
Can anyone throw some light on what could be going on... no turn signals and when you activate the hazzard lights smoke appears out of the steering column... i would be very grateful for any input.
Old Nov 13, 2015 | 07:09 AM
mmandley's Avatar
mmandley
I have to agree that nothing with the brake system has anything to do with the turn signals. The car doesn't use the brake system or components to ground anything.
What is most likely happened is the turn signal switch in the column was almost bad, and now failed while driving the car to the shop, then test driving and you driving it home.
The Hazard switch and the turn signal switch are two different switches that interface together to light the lights.
The hazard switch is probably causing a short when you activate it making the smoke.
You also have the Horn switch, which I have typically found then the turn signal switch has a catastrophic failure will be effected as well in some faction. The horn unlike other switches is actually Live all the time, when you press the Horn button you are actually grounding the circuit causing the horn to blow, unlike other circuits that are dead and activating the button sends a voltage.
I would start by replacing the turn signal switch and seeing if that takes care of your problem.
Also on another note, honestly at no point do you pay more attention to your car and its problems then right after you have someone else work on it. You will inherently pick up problems that have been lingering when you pick up the car because your senses are heightened.
Old Nov 16, 2015 | 05:41 AM
aussiec4corvette
Cruising
Thanks for the reply... appreciate it...
Yes, you would be right that it probably was going to go and just happened to do it when getting something else fixed.
What puzzled me is after I replaced the burnt out fuse it all worked until my stop light fuse then also melted and no more turning signals.
Isn't there some connection with the stop light and turning signals... like an interruption of the stop light setup to activation the turning signals.
Anyway I have ordered a new signal switch and when it arrives I have got someone to put it in... I do most of the work on my corvette but the pulling of the steering wheel seems a bit tricky and so I am getting someone who works on corvettes to fix it.
I just hope that once it is all done it doesn't short out again because there is something else amiss.
Old Nov 16, 2015 | 07:24 AM
Dalesc4's Avatar
Dalesc4
Where abouts in Aus are you?
Old Nov 16, 2015 | 08:12 AM
shootnstarz's Avatar
shootnstarz
My 89 just quit about 10 miles after an oil change, but it was the ICM.
The brake/hazard/turn signals are all wired together somehow, so the turn signal overrides the brake lights and the brake lights override the hazard lights.
Learned about this on an old F-150 so I'm no help on a Corvette.
Rick
Old Nov 18, 2015 | 05:40 AM
aussiec4corvette
Cruising
Adelaide
Old Nov 18, 2015 | 06:09 AM
crowz's Avatar
crowz
The smoke out problem your having could be from the conversion when the car was imported. From what Ive read in various forums its not uncommon for wiring issues to arise from the conversions.
If something wasn't quit right the lifting alone to do the brakes could of set off a problem you already had from it.
There is no way to know for sure just throwing that out there as a possible problem.
Old Nov 18, 2015 | 06:50 PM
aussiec4corvette
Cruising
The car is 27 years old and things fail on it an different intervals... had to replace the petrol pump in the tank and the main primary fan recently... both just died... most likely what happened with the turning signal is the people who put the new brake pads in and did wheel alignment took it for a test drive and lifted the steering wheel tilt up (I have it as low as you can get)... this probably pinched some wires in the turning signal switch or the wire had been worn out over the years through movement in the steering wheel... the ignition lock is worn and jams when I put it in lock... you can also pull the key out of the ignition when the car is running... so I have bought a new ignition lock and getting that done at the same time.
These cars need constant care and replacement of old or worn parts... but that's part of owning a C4 or older vehicle... most things I have fixed or replaced myself, but the steering wheel column is something I don't feel comfortable with pulling apart so I have someone who works on Corvettes to fix it
Fortunately the C4 is not my daily drive and I can just leave it sitting until parts arrive from the States... if it was my daily drive I would be pulling my hair out all the time.
Old Dec 4, 2015 | 03:11 AM
aussiec4corvette
Cruising
Found the problem... I got a guy who has 30 years of experience on working on C3s and he said he could do my C4 because the setup in the steering wheel is pretty similar... ordered a new turn signal switch... but that wasn't the problem... the turn switch was OK... a small piece of metal was floating around in the switch which caused the short... anyway got a new signal switch in a great heavy duty flasher can (can even reset itself) and a new plastic thingo for the horn so the horn works no matter where I hit the horn button.
Old Dec 4, 2015 | 06:43 AM
Joe C's Avatar
Joe C
:ch eers:
To Got A Problem
