High pressure oil
Nov 15, 2015 | 03:25 PM
Cruising
High pressure oil
Hi !
The oil pressure of my C$ 96 Corvette is running high....idle or running!!. I changed the engine oil pressure switch,,but no difference in pressure. Welcome your intake!.
Thanks!
Hector B.
Nov 15, 2015 | 03:45 PM
are you sure you changed the right sensor? where was it?
Nov 15, 2015 | 03:53 PM
What is pressure? At idle and running (what RPM)????
Nov 15, 2015 | 05:23 PM
Cruising
Quote:
Originally Posted by
antfarmer2
Hi!
Thanks for answering! Changed the sensor located at rear of engine, driver side. Moved wiper motor to gain access to it.
Hector B.
Nov 15, 2015 | 05:26 PM
Cruising
John A. Marker
Hi!
Idle the pressure is around 40,,about 1500 RPM,,,more or less,,,increases at higher speed.
Nov 15, 2015 | 05:52 PM
what would you like it to be? does it go down some once hot at idle?
Nov 15, 2015 | 06:11 PM
2018 C1 of Year Finalis4
My 96 runs just under 60 on my gage at idle at start up.
Owner’s Manual notes from 20 to 80 (PSI) as normal and can go as low as 6 psi in some extreme heat situations
Nov 15, 2015 | 06:12 PM
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
hbermu
Hi!
and your problem with that?
Nov 15, 2015 | 07:01 PM
Cruising
antfarmer2
No,,,,stays the same,,,,only increases with speed. My concern is because up to a few days ago it was lower,,,between 10 and 20.
Nov 15, 2015 | 07:03 PM
Cruising
ColaBear
Ok,,,,then if you guys think this is ok,,,then is ok with me.
Thanks for your answers!
Nov 15, 2015 | 09:13 PM
What has happened (or what parts have you changed) to make it go from 10-20 to now 40?
1500 rpm idle is a little high. Without the AC turned on, should be around 750 to 800 rpm.
Nov 15, 2015 | 10:01 PM
Cruising
ColaBear
Changed the engine oil pressure switch after i noticed the increased pressure.
Nov 16, 2015 | 09:45 AM
Before when it was at 10-20 psi, what RPM was the motor at (at idle)?
Does it always idle at 1500 RPM?
