1986 Water Pump
Old Nov 25, 2015 | 11:44 PM
rrt898's Avatar
rrt898
Default 1986 Water Pump
I have 86 L-98 coupe. I want to replace the water pump when I change the cam. I wanted to use an AC Delco unit. I did a quick search on rockauto and found two. The question is why is one $38.99 and the other one is $184.79. I must be missing something...
https://www.rockauto.com/catalog/mor...nid=476&jpid=3
https://www.rockauto.com/catalog/mor...nid=476&jpid=8
Old Nov 26, 2015 | 07:56 AM
WVZR-1's Avatar
WVZR-1
If I had a known OE/GM casting now and it wasn't a leaker or wobbler I'd rebuild what I have or hire the build done. There's a few quality specialty builders that offer the services with warranty and I'd be likely more comfortable with the product.
I don't shop RA - I'm a "hater" I guess. I didn't use your links and I don't even use RA for price comparisons.
Old Nov 26, 2015 | 09:04 AM
ex-x-fire's Avatar
ex-x-fire
I'd get an edelbrock pump Very good product.
Old Nov 26, 2015 | 10:08 AM
rrt898's Avatar
rrt898
Does anyone know if I have a long or short water pump? Also, do I have a standard or reverse rotation pump?
thanks again.
Old Nov 26, 2015 | 10:21 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
thanks again.
ALL CORVETTES got a short W/P. and its a standard rotation. a reverse pump started with the 92 LT-1
Old Nov 26, 2015 | 10:26 AM
WVZR-1's Avatar
WVZR-1
Are you SURE? I believe you might need to check again !! Sometimes "flow" and "rotation" is confused.
Old Nov 26, 2015 | 11:08 AM
Nowhere Man
your right for a serpentine belt set up its a reverse rotation
Old Nov 26, 2015 | 12:12 PM
WW7's Avatar
WW7
AC Delco pumps are now made in China, I got one 2 months ago from a dealership and it said Made in China right on the box...When I asked the parts guy he said thats where they are made now ...I sent it back and got a Stewarts stage 1 pump from Summit racing because most of the guys on here said it was a very good replacement.....WW
To 1986 Water Pump
