84 will not start
Old Nov 26, 2015 | 03:17 PM
Allen78's Avatar
Allen78
Cruising
Default 84 will not start
Ok i have a 84 that will not start all of a sudden. I whent in to a store for 5 minutes and came out and it won't start no problems at all at first. I changed the coil and module in the distributor but still no luck it's getting gas just no spark any help or thoughts will be appreciated thanks.
Old Nov 26, 2015 | 06:36 PM
jose7740's Avatar
jose7740
Check for any codes stored on the computer, maybe you can find the problem.
Old Nov 26, 2015 | 07:05 PM
gjohnson's Avatar
gjohnson
Check ECM fuse
Old Nov 27, 2015 | 01:17 AM
Cliff Harris's Avatar
Cliff Harris
Are the injectors pulsing? If yes, then you have fuel and reference pulses from the ignition module.
Old Nov 27, 2015 | 08:38 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Check spark plug wires.
My '87 was having problems due to wires at strange times. It'd run fine for 30 minutes, stop and restart after 5 minutes, it'd die in less than a block. Wires had cracked.
Old Nov 27, 2015 | 01:11 PM
Allen78's Avatar
Allen78
Cruising
Got it going again had to treat it like an old carburetor pump the hell out of it and hold it to the floor and it started up but ran link **** for about 4 minutes and now no problems starts right up i did put 3/4 a tank of 98 octane it after it started
Old Nov 27, 2015 | 01:42 PM
DinoBob's Avatar
DinoBob
You could put 108 octane in it, makes no difference. I doubt very highly it is gasoline related. Keep an eye on it, I suspect this is not the last we will hear of this. Fuel filter and pump are my two top suspects.
Old Nov 27, 2015 | 01:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
To 84 will not start
