84 crossfire engine compatability.
Old Dec 4, 2015 | 08:33 PM
dads84vette's Avatar
dads84vette
Cruising
Default 84 crossfire engine compatability.
So, dads vette needs a engine rebuild. We are loking to pick up a temp motor while we work on it. What year motors will bolt over? I already expect mounts, sensors, intake, front end. Is there anything the will work, or should we go another route?
Old Dec 5, 2015 | 02:27 AM
Hot Rod Roy's Avatar
Hot Rod Roy
The long block SBC 350 engine in the '84 is standard for many years! The only special features are the bolt-on parts: intake system (including the CFI), rocker covers, oil pan, distributor, a few sensors. These long blocks are so common you can probably find one completely rebuilt at less cost than rebuilding yours! Do a local search. You might be surprised! I ended up with a four-bolt mains engine when I did mine.
While it's apart, modify the intake manifold to match the ports to your heads. There are many suggestions on this forum about doing that mod.
Do the engine swap only one time that way! You don't even need to remove the hood!
Tip: Don't remove the CFI bodies from the top plate! You'll mess up the balance calibration between them. It looks like there's a bolt under the bodies, but the bolts at those two locations go thru the throttle bodies. Remove only the one bolt at the edge of each body.
Tip: Don't crack your magnesium valve covers.
Old Dec 5, 2015 | 08:12 AM
ex-x-fire's Avatar
ex-x-fire
I'd find a roller cam equipped short block in the long run. With all these LS swaps today, finding a 87 up L98 shouldn't be a problem.
Old Dec 5, 2015 | 11:13 AM
biker4ever's Avatar
biker4ever
don't know if your close or not but do have a 1984 enging out of a vette am parting out only 60000 miles on it
Old Dec 5, 2015 | 11:18 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
google
C4orce project.
Old Dec 5, 2015 | 01:53 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
1st gen sbc 350 should all bolt up, 69 to 91. You may have to reuse your heads, intake, distributor, etc... (your sensors may need to work on 84 Corvettes)
Old Dec 8, 2015 | 07:27 PM
ghoastrider1's Avatar
ghoastrider1
I THINK, 87 and newer engine will require a different flexplate,, one piece rear main seal. something LIKE THAt
Old Dec 9, 2015 | 12:31 AM
johnnymo63's Avatar
johnnymo63
86 and before are 2 piece rear main seals and 87 to 91+ Vortec truck engines had 1 piece. I would assume that most engines would come with their own flexplate or flywheel, because they are balanced with the rotating assembly.
Old Dec 9, 2015 | 09:19 AM
c4cruiser's Avatar
c4cruiser
Why the temporary engine? Are you concerned about retaining the original block so it matches the VIN?
Given the extra effort for two engine swaps, why not buy a short block? You can find a variety of quality GEN 1 short blocks for that era and then you only need to pull the old engine, install the parts and accessories from the old engine and re-install. But I would suggest that the old cylinder heads be checked out before you put them back on.
Old Dec 9, 2015 | 09:30 AM
ghoastrider1
good advice and not to be taken unless your really bucks down or want to keep numbers
Old Dec 9, 2015 | 09:33 AM
ghoastrider1
your correct John but isn't there some sort of Converter problem? There is something in my mind that raises a red flag in the swap..heck, maybe its just hungry for a colts win.
Old Dec 9, 2015 | 04:00 PM
johnnymo63's Avatar
johnnymo63
You might be right about that. An older engine would have mated to a 350 or 400 turbo but the newer would have been bolted to a 700R4. I'm pretty sure the converters are different.
Old Dec 9, 2015 | 05:27 PM
ghoastrider1
maybe one is a three bolt, bolt on and the other is a four bolt, bolt on?
Old Dec 10, 2015 | 12:02 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Guys, converters have nothing to to w/the OP's question. The flex plate handles any converter issues. Flex plates are less than $50. Buy the motor you want, if it has the wrong flex plate for your converter, buy a flex plate. Simple.
To 84 crossfire engine compatability.
