Service LTPWS light?
If you would like to clear the SERVICE LTPWS light
from your driver information center permanently, see
your dealer.
Can this be done without going to the dealer? If you pull the fuse, it kills cruise and DRL's also. How would the dealer get rid of the light?
Edit: After reading about 25 threads with the same question, I think I'll just pull the bulb. Thanks, Jack
your dealer.
Removing bulb/bulbs or detaching the connector from the module is the only way. Connector at the module is a tough reach.
