sos!!!
Old Dec 9, 2015 | 04:44 PM
Salvo's Avatar
Salvo
Default sos!!!
Does any one Know what this is????
Old Dec 9, 2015 | 04:56 PM
Salvo's Avatar
Salvo
Hello,
Sorry for that last post! I didn't mean to post it without some more info.
I had a service engine light. I scanned it would come up as a engine temp sensor. I replaced both sensors and still the light would come on. Car ran ok but hesitated if I punch it. Fast forward two months... I had some time today and traced back some wires from the water pump sensor and came across this taped up to the wires coming from water pump sensor. I cut it out to see what it could be But some of the numbers are scratched off. When I started the car to put it away the light was off. I went around the block to see how she ran and Now the car runs great!!! Any ideas???
Thank You
Sal
Old Dec 9, 2015 | 04:59 PM
WVZR-1's Avatar
WVZR-1
You haven't mentioned the year in any of your threads but I believe/quite sure the part in the snapshot is the tach filter.
Old Dec 9, 2015 | 05:14 PM
Salvo's Avatar
Salvo
Sorry!!!
92 lt1
Could that make the car run crapy???
Old Dec 9, 2015 | 05:17 PM
John A. Marker's Avatar
John A. Marker
Yes, I believe it is the tach filter fr the LT1 94 and prior.
Old Dec 9, 2015 | 05:46 PM
antfarmer2's Avatar
antfarmer2
Originally Posted by Salvo
Sorry!!!
92 lt1
is showing the same code? how old are the 02 sensor(s)
Old Dec 9, 2015 | 05:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
look at the female ends of the plug. I chased a gremlin on my 94 water pump temp sensor. and the plug was at fault
Old Dec 10, 2015 | 05:05 AM
Salvo's Avatar
Salvo
Sorry!!!
92 lt1
Thank you!
Salvo's Avatar
Salvo
Thanx Guys!
I'm gonna check my plug and 02 sensors...
Old Dec 10, 2015 | 09:27 PM
antfarmer2's Avatar
antfarmer2
Thanx Guys!
any results?
To sos!!!
