Dexron V1 trans fluid
Old Dec 20, 2015 | 05:05 AM
enventr's Avatar
enventr
Default Dexron V1 trans fluid
I have a 95 with auto. I had bought some cases many years ago of Dexron 3 or 4. I'm running out of this (Castrol brand) and wanted to know if this new formula Dexron V1 is compatible with the old Castrol 3 or 4 before I purchase the trans fluid.
Thank you
Old Dec 20, 2015 | 08:12 AM
WVZR-1's Avatar
WVZR-1
Thank you
That gets argued/discussed a good bit. It's like any lubrication discussion. I have a DexronIII vehicle and I went to the Castrol/Allison TranSynd which is a DexIII Allison spec.
I can't/won't argue or discuss it but when the Dex/Merc was becoming the trend and I ran out of DexIII I went to the TranSynd. I've no regrets. I would use the DexVI vs. the Dex/Merc product if that were my only choice.
Old Dec 20, 2015 | 09:06 AM
c4cruiser's Avatar
c4cruiser
You should be able to use the new Dexron 6 ATF fluid with no problems. That fluid is suitable for use in auto transmissions that had used Dexron III.
If you are planning a trans service, I would do a complete flush and use only one fluid type or the other, not a mix of both types.
Old Dec 20, 2015 | 09:48 AM
enventr's Avatar
enventr
Usually every year I suck about 2.5 was out of the fill tube and replace .i want to continue doing so. I was just concerned about the compatibility
Thank you for your response
Old Dec 20, 2015 | 09:54 AM
WVZR-1's Avatar
WVZR-1
How frequently do you do a dump/filter? Current miles? Ever had a filter?
Old Dec 20, 2015 | 12:19 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Use the ATF recommended for you 4L60E transmission.
Old Dec 20, 2015 | 01:35 PM
enventr's Avatar
enventr
Did it about 8000 miles ago but many years. It is a pain due to the X brace (convertible)
Old Dec 20, 2015 | 02:17 PM
WVZR-1's Avatar
WVZR-1
Yes it is and I understand the "suction service". I've a friend that doesn't have a C4 'vert and still does "suction services" more frequently than dump/filter. I added a drain plug to my 4T65E
Old Dec 20, 2015 | 05:59 PM
enventr's Avatar
enventr
The drain is the way to go but I'm always afraid of leaks. My Japanese cars always had the drain plug and was very easy for me. I wish we had factory drain plugs
Old Dec 21, 2015 | 12:23 PM
enventr's Avatar
enventr
Reply from Castrol:
Thank you for contacting Castrol North America.
Castrol always recommends following the guidelines of the original engine
manufacturer for the recommended fluid for use in your specific application.
This information can be found in the vehicles owner's manual or by
contacting the manufacturer directly.
Additionally, for information on all Castrol products (motor oils, ATF,
brake fluid, greases, gear oils), please refer to the Products section for
"Car" of the Castrol US web page
(http://www.castrol.com/en_us/united-states.html).
According to Castrol's Recommendations Guide recommended for use in the
automatic transmission in a 1995 Chevrolet Corvette is DEXRON-VI fluid.
Both Castrol Transmax Full Synthetic Multi-Vehicle ATF and Castrol DEXRON-VI
ATF products meet the DEXRON-VI specification and may be used.
DEXRON-VI fluid is compatible with DEXRON-VI, DEXRON-IIIH, DEXRON-III,
DEXRON-IIE, DEXRON-II and DEXRON type ATF.
Castrol Consumer
Old Dec 22, 2015 | 02:50 PM
Christi@n's Avatar
Christi@n
Thank you
Typical fluid Shelf life is 5 year, take in mind it when you are going to replace your trans fluid
Old Dec 22, 2015 | 06:58 PM
enventr's Avatar
enventr
I did not know that thank you
Old Dec 22, 2015 | 10:34 PM
FirstC4's Avatar
FirstC4
Where did you read that??
Old Dec 23, 2015 | 09:14 AM
enventr's Avatar
enventr
I called Castrol today. The shelf life of trans fluid is 2 years according to them. I was very surprised at their answer
Old Dec 23, 2015 | 09:50 AM
Christi@n's Avatar
Christi@n
Once I've mailed to Mobil about engine oil, they me 5 y for engine oil, 1 y once unsealed.
Even less for trans fluid, as castrol said.
i don't know if oil producer say this in order to sell their products, or is it true.
The only thing I can say you is that I've a Mobil 1 5w30 bottle unsealed here and after one year oil has a different smell and its dye turned from dark Amber to a light Amber.
Old Dec 23, 2015 | 06:21 PM
enventr's Avatar
enventr
Thanks for the info
Old Dec 25, 2015 | 08:10 AM
enventr's Avatar
enventr
More info from Castrol:
Castrol always recommends following the guidelines of the original engine manufacturer for the recommended fluid for use in your specific application. This information can be found in the vehicles owner’s manual or by contacting the manufacturer directly.
Additionally, for information on all Castrol products (motor oils, ATF, brake fluid, greases, gear oils), please refer to the Products section for “Car” of the Castrol US web page (http://www.castrol.com/en_us/united-states.html).
According to Castrol’s Recommendations Guide recommended for the 1995 Chevy Corvette is the Castrol Transmax Dec/Merc. Castrol Transmax Dec/Merc meets the DEXRON-111 Automatic Transmission Fluid specifications and may be used in your application.
Castrol Consumer Relations
If you would like to chat with us, just click on the link below and AL is online and ready to answer your questions with expert advice!
Online hours 9:00am to 5:00pm est Monday - Friday
To Dexron V1 trans fluid
Old Dec 27, 2015 | 10:01 AM
JackDidley's Avatar
JackDidley
I dont understand, fluid going bad after 5 years in the bottle but living 10+ years being used in the trans.
Old Dec 27, 2015 | 11:11 AM
Chrly919's Avatar
Chrly919
I've had my 93 for a year now. The trans fluid was very oxidized when I got it but not burned.
I was going to use M1, but went with Maxlife Full Synthetic. I've used this for years in all my cars with good results. I did a cooling line flush with a new filter. I'll probably do a fill tube drain and add next year. My wife's 2001 is up for service this spring and ill probably do the same they. Still run M1 engine oil and diff fluid.
Old Dec 27, 2015 | 11:53 AM
enventr's Avatar
enventr
I don't understand this either but Castrol said their recommended shelf life is 2 years. The auto supply store did not even know this. I have been always using Castrol in my Vette.
