LED Taillights
Old Jan 12, 2016 | 12:41 PM
Mejjr's Avatar
Mejjr
Default LED Taillights
So...thinking about putting led taillights in my 95 coupe. Any suggestions on type? Any experiences?
Old Jan 12, 2016 | 06:23 PM
1984Z51auto's Avatar
1984Z51auto
In my opinion it is a lot of trouble for not much gain. Adding the resistors needed to get the directional and emergency flashers to work is an extra bit of work and the only real plus is your brake lights illuminate a touch faster using the LEDs. I'd spend the money and time on other things I think.
Old Jan 12, 2016 | 07:23 PM
Klondike's Avatar
Klondike
Just put LED replacement bulbs in my friends 88 the other day. They were 2 to a package and about $22.00! Don't remember what the brand name were. They are white LED replacement bulbs for the filament type bulbs that were in there, so they clicked right in the sockets. They are much brighter than the old bulbs BUT, like mentioned above, they don't put enough load on the turn sig. flasher to make it cycle. Two alternatives are to add load resistors (which he didn't want to do) or replace the turn signal flasher bimetallic can with one made for trailer towing. That module has a timer ckt. that makes it flash and isn't affected by the amperage load on the line. We haven't got one of those yet but I've heard you can get them at auto parts stores like Pep Boys & NAPA or trailer rental places.
Old Jan 12, 2016 | 10:47 PM
Goldcylon's Avatar
Goldcylon
I've been running something similar to these for 8 years now without a problem. You can see them under EBay auction number 161928497637
All that is needed is an electronic flasher to make them work. This style plugs into the original socket and replaces the Rear lenses
Old Jan 13, 2016 | 06:35 AM
TorchTarga94's Avatar
TorchTarga94
EL12 Flasher from your local Advanced Auto Parts
(4) - 1157 (45)LED tower bulbs from SuperBrightLeds. Make sure you select them in RED.
Result: Driver side = LED, Passenger Side = Halogen. Cheap enough, effective, durable, and it doesn't give off that "light brite" look like the individual LED panels do. WAY brighter than the stock bulbs and illuminate much quicker.
Old Jan 13, 2016 | 06:54 AM
dizwiz24's Avatar
dizwiz24
https://www.youtube.com/watch?v=Vq1nEmGMOzI
curious why you need to select them in red when the stock bulbs are white???
Old Jan 13, 2016 | 06:58 AM
TorchTarga94
It is the way the light is filtered through the lens. Different ball game for LED.
Straight from Super Bright LED's website:
Old Jan 13, 2016 | 10:48 PM
C4.Ray's Avatar
C4.Ray
I think LED Tail Lights is a very viable mod these days. I know the stock tail lights on y 93 looks dated and weak. Plus the added to better security of bright LEDs over stock. Price over added security in the event of an accident is key here.
This forum has a dedicated LED Tail Light Vendor?
Old Jan 14, 2016 | 10:33 AM
Christi@n's Avatar
Christi@n
Tridon el12 is what I'm using now. So are you saying that with it no need to fit resistor?
Old Jan 14, 2016 | 10:35 AM
TorchTarga94
Correct.
Old Jan 14, 2016 | 11:10 AM
Christi@n's Avatar
Christi@n
Correct.
Is the Same for new super bright plasma led bulbs??
I would take these
Old Jan 14, 2016 | 11:30 AM
TorchTarga94
I would take these
Never heard of Plasma LED's. I would suspect it is the same and the term, "plasma," when it pertains to an LED is just a marketing term to make their LED bulbs sound superior to others. An LED is just a diode that lights up when electricity is passed through it. Nothing fancy going on here.
Old Jan 14, 2016 | 04:47 PM
C5 4me's Avatar
C5 4me
http://s1120.photobucket.com/user/go...6f269.jpg.html
I have these as well,Very brite & all you need to do was switch flashers
Old Jan 14, 2016 | 04:54 PM
Christi@n's Avatar
Christi@n
This is what i was talking about
They are a little bit doffferent from what you pic posted above
Old Jan 14, 2016 | 04:56 PM
Christi@n's Avatar
Christi@n
A pic about it
Old Jan 14, 2016 | 11:22 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Look at the back of a tractor trailor's LED tail lights when they start to burn out. One or two, then three or four of the individual lights burn out. Then try to match one. Many trucks have a few different type lights as they most likely could not match what was there before. Not a good look.
Old Jan 15, 2016 | 01:09 AM
C4.Ray's Avatar
C4.Ray
Who is the Go-To Vendor for these Lights?
To LED Taillights
Old Jan 15, 2016 | 03:20 AM
Christi@n's Avatar
Christi@n
Plasma led?? You can find them on ebay or amazon.
1175 cree led plasma bulb
Or just 1157 plasma led bulb
Old Jan 15, 2016 | 06:33 AM
TorchTarga94
That video is a little misleading to me. It shows the 1157 incandescent a little brighter than the LED Tower Bulbs. This is because there are not 45 individual SMD LED's on the tower like the ones from Superbright LED. The ones I posted will fill the entire tail light housing with light better than those "Plasma" LED's with the chinese projector on it that puts most of the light straight out instead of 360 degrees. The "Plasma" may give you the illusion that they are brighter head on, but from the side I can almost promise they won't be as bright as the LED Tower Bulbs.
The LED replacement bulbs with the little projector on top would be more suitable for something that is supposed to throw light (headlight/fog light), not something that is supposed to glow/illuminate from all visible directions.
Old Jan 16, 2016 | 02:01 AM
The Thomas J's Avatar
The Thomas J
I have a set 1175 cree led plasma bulb's in myMercedes as fog lights. They are brighter and have a better field of light than the HID head lights. However, the projector on one of them has stopped working and has lessen the brightness considerably. It didn't even last a year.
