My Automatic Corvette has been running unusual and I wanted to know if anyone could help figure out what is wrong?
When I have it in Drive and I am sitting at a stop light with the AC or heat on, it idles oddly - it almost feels like it is jumping in and out of neutral.
When I shift it to neutral it seens to run fine or if I just don't turn on the AC or heat it runs fine.
Any Ideas at all??? :confused:
Thank you for your time.
Depending on the year and motor in your car, if it has an L98, I just had a similar issue with my 89 6 speed and it turned out to be the Idle Air control valve. Good as new after replacing it
