ecm computor removeal
Old Jan 16, 2016 | 11:58 AM
Tripower delight's Avatar
Tripower delight
Default ecm computor removeal
I have a 95, I need to get to the clutch reserior the ecm computer is right on top of it. It needs to be moved, I don't see any bolts holding it down ots on some kind of bracket, just like to know has anybody done this.
Old Jan 16, 2016 | 12:32 PM
Klondike's Avatar
Klondike
There are two screws on the front edge that hold it into a plastic frame. With those two screws out, you can pull it forward a little and out of the holding frame, with all the harnesses intact and just lay it over out of the way. If you need that plastic holder frame out of the way too, there is a bolt that fastens it to the driver side hood latch. With that bolt out you can unclip that holding frame and it slides forward off of a pin/rail located in it's middle. You can now see straight down onto your clutch master cyl.
Old Jan 16, 2016 | 07:53 PM
Tripower delight
Thanks pal that was very helpful,the clutch master cyl was dry. I can drive my car again thanks pal.
To ecm computor removeal
