Ball joint ripoff
Old Aug 30, 2002 | 02:00 PM
rocketfinger's Avatar
rocketfinger
Default Ball joint ripoff
Yesterday I started looking around for ball joints and I don't mind telling you that $100 at both Otterzone and Pep Boys harshed my buzz a little.
What are these things, duranium alloy? If that were true, I wouldn't be shopping around for 'em would I? I could see that for sealed units, but these look like regular ol' $30 parts-bin stuff.
Maybe it's a case of 'Corvette owners have too much money, let's just take some' but I'd sure appreciate it if somebody could point me in the direction of some sanely priced ball joints.
Old Aug 30, 2002 | 02:11 PM
Bluevette85's Avatar
Bluevette85
Default Re: Ball joint ripoff (rocketfinger)
Check out www.p-s-t.com
Old Aug 30, 2002 | 02:23 PM
JonM's Avatar
JonM
Moog Part # K6345 Lower - 62.26
Moog Part # K6346 Upper - 65.40
http://www.rockauto.com/
Old Aug 30, 2002 | 07:50 PM
1MoorTym's Avatar
1MoorTym
Default Re: Ball joint ripoff (JonM)
Thats the stuff and the place, don't use anything else.
[Modified by 1MoorTym, 6:51 PM 8/30/2002]
Old Aug 31, 2002 | 10:35 AM
Midnite 88's Avatar
Midnite 88
Default Re: Ball joint ripoff (1MoorTym)
I just ordered everything to recondition the entire front and rear suspension on my '88 Coupe for around $350.00. That is for ball-joints, tie-rod ends, control arm bushings, strut-rod bushings, carrier bushings and sway-bar bushings. These are poly-graphite bushings.
I ordered everything from P-S-T on the advise of a fellow forum member.
Thanks,
Mike.
To Ball joint ripoff
