need help
Old Jan 18, 2016 | 03:17 PM
ace26149's Avatar
ace26149
2nd Gear
Default need help
have a 86 vette and the fuel pump had to be replaced in the meantime I replaced the ecm,ign. control module and the tps. Now the instrument cluster panel is going off and on with different readings and being an auto. speedometer is reading a 35 mi. per hr. when engine is at op temp. what is the cause of this and what can I do. I replaced some relays and am still using the original prom that it came with.
Old Jan 19, 2016 | 02:11 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
www.batee.com
