I am having a starting issue that is quite odd. I go to turn the key and all of the lights come on as normal, but when i go to crank it it completely dies and i am not able to even get the interior lights to come back on. When i go to jump it, i attach the cables to my battery only and everything returns to normal without another car on the other end...?
It will then start with the cables attached and dies if i try to start it with out them on. I want to say it is a simple fix but i am not experienced in mechanics. Please help...
P.S. - I also have an issue where my rear interior dome lights never shut off so i have removed the bulbs.
Sounds like you could have a bad or loose connection at the battery. I would take the cables off the terminals and clean them. After that a bad connection on the other end of the cables or bad cable(s).
Gary
Be sure to take the bolt out of the end of the cable and clean under the head.
