c4 Led Tail lights problems
Old Jan 22, 2016 | 07:13 PM
Raybo123's Avatar
Raybo123
Cruising
Default c4 Led Tail lights problems
Just replaced my 1992 Chevy corvette tail lights with LED and blinkers don't work. I'm told I need to replace flasher relay but need to remove dash to get to relay. Can you help?
Raybo
Old Jan 25, 2016 | 06:31 AM
TorchTarga94's Avatar
TorchTarga94
You need to remove the driver side hush panel under the steering wheel. First remove the plastic panel on the left above the hood release. There are 3 Torx screws holding it in place. Once that is removed, you can unscrew the carpeted panel, there are about 6 screws holding this in place and I always use a 7mm socket to remove these screws. Once the hush panel is down unbolt the OBD2 connector with the same 7mm socket and unclip the courtesy light. Loosen the bolts on the aluminum hush panel underneath. I believe it is a 12 or 13mm. This will let you drop the the aluminum panel just enough to see the flasher. It will be up and under on the left side, can't miss it. It's held in by a spring clip of sorts.
Old Jan 25, 2016 | 07:14 AM
Raybo123's Avatar
Raybo123
Cruising
Thanks!! Sounds like i have to replace the Hazard relay also. Any idea where that is?
Raybo123's Avatar
Raybo123
Cruising
Old Jan 25, 2016 | 07:52 AM
TorchTarga94
No need to replace the hazard flasher, everything will work fine with just an electronic turn signal flasher.
Old Jan 25, 2016 | 04:10 PM
Goldcylon's Avatar
Goldcylon
All you need is an electronic Flasher
Old Jan 25, 2016 | 08:59 PM
Raybo123's Avatar
Raybo123
Cruising
Thanks will replace turn signal flasher and let you know.
Old Jan 25, 2016 | 09:35 PM
C5 4me's Avatar
C5 4me
That's what I did, And it's money well spent
Old Jan 26, 2016 | 07:11 AM
Raybo123's Avatar
Raybo123
Cruising
Default C4 Led tail lights
Very nice!! Looks just like mine. Where did u get the LED Flasher? Does it have a ground wire??
Old Jan 26, 2016 | 08:04 AM
TorchTarga94
Advanced auto parts, autozone, etc... There is no ground wire. You want the Tridon/Novita EL12
http://shop.advanceautoparts.com/p/t...el12/5081289-P
Old Jan 26, 2016 | 08:28 AM
Raybo123's Avatar
Raybo123
Cruising
U the man!! I'll let u know how I make out!! Thanks
Old Jan 27, 2016 | 06:14 PM
Raybo123's Avatar
Raybo123
Cruising
[QUOTE=Raybo123;1591404407]U the man!! I'll let u know how I make out!!
Old Jan 27, 2016 | 06:37 PM
C5 4me's Avatar
C5 4me
[QUOTE=Raybo123;1591417360]
Looks good
Old Jan 27, 2016 | 06:59 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
You should remove that ZR-1 badge from your bumper.
Old Jan 29, 2016 | 05:47 PM
Raybo123's Avatar
Raybo123
Cruising
Great directions!! Found relay replaced with the EL12 work good until I turn on the lights the they won't blink? Any ideas? Mine is a 1992.
Thanks Ray
Old Jan 29, 2016 | 06:08 PM
C5 4me's Avatar
C5 4me
Do you have LEDs in the front? I switched my to LEDs & ugh what a nightmare. So I went back to standard bulbs
Old Jan 29, 2016 | 06:13 PM
Raybo123's Avatar
Raybo123
Cruising
Yes I do, but changed them back to regular bulbs but no change??
To c4 Led Tail lights problems
Old Jan 29, 2016 | 06:30 PM
C5 4me's Avatar
C5 4me
I know it's a pain but I went all back to stock, just to make sure flashers were working, once I was sure the stock system was ok, I then switched out my tail lights back to the LEDs and everything has been great.
Old Jan 29, 2016 | 06:46 PM
Raybo123's Avatar
Raybo123
Cruising
Yiu did that with the new flasher relay?
Old Jan 29, 2016 | 06:56 PM
C5 4me's Avatar
C5 4me
Yes, it works on standard bulbs as well.Its a PITA, but I had to figure out what went wrong after everything worked fine before I changed everything.
