Battery Maintainer Hookup
I use this so I don't even have to open the hood. I just pull into the garage, open the car door and reach down to grab the cigarette adapter connected to the Battery Tender and plug it in before I exit the car. Simple and easy. If you have a different brand I'm sure you adapt the plug to fit.
Works great, and could not be easier to connect/disconnect. No mods required to the car, nothing to connect directly to the battery. Easy to move from one vehicle to another.
I've set up chargers like this for several friends, who've also been using them for years and love it.
With the fuse in the lighter plug that I added to the charger, plus the fuse that's in-circuit with the wiring harness that feeds the lighter socket in the car, I have zero worries about this hook-up starting a fire.
Live well,
SJW
The issue is the cig lighter provides a "point contact" at best. (Think of a very tiny wire to carry the charging current.) If that contact is further compromised with corrosion/ash, etc, then the issue becomes compounded.)
However, the current from a battery tender is usually quite low which reduces the heat potential, and if the contacts are clean - well, even better. And, still better, some tenders only pulse the battery, which also goes a long way toward reducing over-heating.
But, on the flip side, it IS an unattended connection, after all. And, there ARE better ways to access the battery (e.g., eyelet rings on the battery terminals or the clamps intended for the battery terminals (like the ones that come on the Battery Tender chargers) - which don't pose a problem.
I use the battery spring clamps that come with the Battery Tender. I leave them on the battery all the time - never a problem! Removing the charger before taking the car out, I simply put the protective cap on the end of the wire and coil the pig-tail up and stuff it between the battery and the inner fender till I get back. (That way I don't have to be struggling to get to the battery terminal tucked under the ECM.)
I use the cig lighter to run my Garmin nav-aid, or charge my phone, but I'm always present when those items are running; never running unattended. The fact that I don't smoke and the contacts are clean helps as well. If someone wants to say I'm paranoid...well, I've been called worse! In my defense, although I haven't ever had a melted a cig lighter socket or had a fire either, as a gas station mechanic I have seen several cig lighter sockets that did over-heat for various reasons - the source of my paranoia, I guess!
So, I'm w/ you. Others are welcome to do what they want. But, NO cig ligher here, far as battery charging/maintaining goes, especially when the pig-tail is right there - all I have to do is pop the hood and voila!
