Speedometer Calibration Help
Old Jan 26, 2016 | 01:08 PM
RVY's Avatar
RVY
Default Speedometer Calibration Help
I need to replace the driven gear in my 1993 Vert 700R4 transmission. I need a #38 driven gear. Can any one tell me what (stock) driven gear is in there now? Will I require a new speed sensor?
RVY
Old Jan 26, 2016 | 01:37 PM
WVZR-1's Avatar
WVZR-1
RVY
What was the rear gear RPO "as built" on the SPID label? It should be cut and dried. You determined the 38 tooth how?
Old Jan 27, 2016 | 09:57 AM
Kevova's Avatar
Kevova
The speedo gears are color coded and the tooth count is normally stamped on them. You be able to replace just the gear.
To Speedometer Calibration Help
