Emergency Brake Problem
Old Jan 27, 2016 | 08:42 PM
Nascar's Avatar
Nascar
Default Emergency Brake Problem
1996 corvette problem with emergency brake, I push on the button and pull up on the handle and it doesn't catch just goes back down has any one had this issue before.
Old Jan 27, 2016 | 08:57 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Don't push the button. When you want to release the e-brake, push the button.
antfarmer2's Avatar
antfarmer2
how would you get out of the car with it up?
Old Jan 27, 2016 | 08:58 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Don't push on the button while pulling the handle up.
You only push the button in when you want to release the brake.
To Set Brake:
1. Pull handle up, you should hear a ratchet sound as it pulls up.
2. Once set, the handle will go back down leaving the parking brake set.
To Release Brake:
1. Pull handle up to take out all the slack, hold button in and put a little "up tension" on handle.
2. The ratchet should release, and while holding button in move the handle all the way down.
Old Aug 17, 2016 | 11:34 AM
CA1992C4's Avatar
CA1992C4
To Set Brake:
To Release Brake:
Thank you for that information!
I was having trouble climbing out of our 1992 C4 after setting the parking brake - this clears that issue up.
Old Aug 17, 2016 | 05:24 PM
CREWZIN's Avatar
CREWZIN
While we're on the E-brake questions and answers. Had to use my e-brake for the first time since I can ever remember. When I put it down, the red light on the info panel stayed on. Car rolls OK, and back wheels don't overheat so in asking around I'm told there's a micro switch down by the back end of the handle that might be my problem. Apparently the front seat has to come out to have access to the cover on the e-brake handle. Anyone ever mess around with this micro switch. Might it just need adjustment or lube to get the light to go off? Thanks in advance.
87 Coupe.
Old Aug 20, 2016 | 11:02 AM
CREWZIN's Avatar
CREWZIN
To answer my own question. Took the seat out and the problem wasn't the micro-switch but a small electrical connection on the master cylinder that had come off. Put it back on and the brake light switch went off.
To Emergency Brake Problem
