85 C4 Positive Battery Cable Problem
Old Feb 1, 2016 | 08:42 PM
Radical85C4's Avatar
Radical85C4
2nd Gear
Default 85 C4 Positive Battery Cable Problem
I bought an 85 Corvette without an engine. I then build one in my garage and installed it. The wiring harness has a 2 or 4 gauge power wire that goes to the starter along with a small 12 gauge that turns the starter on an off, I assume. The problem is that the positive battery cable is detached and I realize one end goes to the battery but where is the other end supposed to be attached? It isn't long enough to go to the starter so where does it attach to energize the electrical system including the starter? I appreciate any light you can shed on this issue.
Old Feb 1, 2016 | 09:05 PM
Raidmagic's Avatar
Raidmagic
It goes to the large lug on the starter.
THE 383 admiral's Avatar
THE 383 admiral
The lead from the main battery pos would feed your Maxi fuse blocks
Old Feb 2, 2016 | 01:00 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Ahh and you built the engine?
Get a Haynes manual
Old Feb 2, 2016 | 01:32 PM
Radical85C4
2nd Gear
You must be right. I figured out the routing and the cable now reaches the starter. I was thrown off by the facts that other wires were already attached to the starter and the positive battery cable didn't seem to reach the starter. Now that it reaches, all is good. Thanks.
Old Feb 3, 2016 | 10:46 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by JrRifleCoach
Get a Haynes manual
The Haynes manual is excellent for people who are just learning how to change their oil!
To 85 C4 Positive Battery Cable Problem
