i am a novice on corvette's. i removed the pan inside the storage compartment on the drivers side and found what looks like a pump with metal lines coming into it. also a silver rectangular box with a connector and a lot of wires. any ideas what i am looking at? i saw these when i was trying to get a new stereo to work.
If it is like my '88, this is where the Bosch ABS brake system is based. Apparently, GM did not have an ABS ready at this point or for whatever reason, went with a Bosch system.
ok, thanks. a big help,now i know not to fool with it. now i just have to figure out why the speakers are dead.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by TNVETTE86
ok, sounds like this is my problem. where is the amp located?
Each speaker has its own amp.
The Forum has an audio section. Ask your questions there. Also learn to use the search feature here as posts and threads from the past will answer most of your questions. Look over the stickies too.
wow!!! i guess you really set the new guy straight. if i had any idea what you are talking abut i might have gone there instead putting it on the general forum. my apologies for what seemed to be a bother, but no more. i will simply go to another site
Tnvette, don't get upset. Ron only said what he did because there are indeed certain questions which come up over and over on the forum and the Search really is everyone's friend. All the info you need is here already.
yep, you are right. i should have taken it for what it was,helping. just having a bad day. i will try to get around the site better. thanks
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
1. In the upper RH corner of the discussion box click on the link to "search this forum"
2. Click on the "Advanced Search" option
3. Enter your "search info" in the Keywords field and select "Search titles only"
4. Select C4 Corvettes 1984-1996 and check the box for "Also search in child forums"
5. Then click "Search Now"
This C4 forum is filled with information and everyone would be amazed at the volumes of data if they just learned to search and read first before waiting for someone to answer to yet another new thread on a subject that has been covered over and over.
