overheating
Old Mar 7, 2016 | 09:13 PM
antfarmer2's Avatar
antfarmer2
I just jack mine up so the fill is the high point and let it bubble out. Could you see through clean? Might be clogged up inside or water pump not pumping good.
Old Mar 7, 2016 | 09:19 PM
rocketrick's Avatar
rocketrick
Cruising
ok so scrubbing it with a brush may have just aggravated the problem ? I mean when I was done from what I could see the front of it looked so good and fresh I was excited so do you think I may have aggravated the problem by pushing stuff further into it ?
Old Mar 7, 2016 | 09:26 PM
antfarmer2's Avatar
antfarmer2
Yep
Old Mar 7, 2016 | 09:32 PM
rocketrick's Avatar
rocketrick
Cruising
ok so your syin I need to pull the radiator completely and pressure wash it ? or is it possible that I can do that with it still in it ? or would I be better just buying a new one ?
Old Mar 7, 2016 | 09:38 PM
antfarmer2's Avatar
antfarmer2
I would pull it and wash it carefully good time for a flush pull your knock sensor and the hose on the other side on yours I think to get all the crap out. See how it looks inside before buying a new one.
Old Mar 28, 2016 | 07:37 PM
rocketrick's Avatar
rocketrick
Cruising
thanks for all the tips and help out there ! I just went and bought another one and put it in and it has helped . however if you jump on the throttle it will still run right up over 250 but as soon as I let off the gas n slow down it drops rite back down just as quick as it went up and I'm not smelling anything like you do when an engine gets hot ' if any one knows where I can get a new targa top for it could you let me know ? thanks0000000000
Old Mar 29, 2016 | 12:42 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Read this https://www.corvetteforum.com/forums...peratures.html
Everything you need to know
Old Mar 31, 2016 | 01:26 PM
Gibbles's Avatar
Gibbles
I like to put a tiny hole around the flat space on the sides, it allows air to bleed out so when refilling you don't starve your heads of coolant ect.
(I got the idea from an expensive thermostat years ago, it had a little check valve)
just a tip to help when your putting it all back together, very common for that little pocket to cause an overheat right after a service.
The other trick is to just remove the thermostat while your filling to confirm it gets to the intake. from there it's easy top off as it gets warm.
Old Apr 4, 2016 | 08:08 PM
rocketrick's Avatar
rocketrick
Cruising
can any one recommend a good place to find a good replacement seat cover
Old Apr 4, 2016 | 08:20 PM
antfarmer2's Avatar
antfarmer2
Yes look at my leather seat thread.
Old Apr 4, 2016 | 08:25 PM
rocketrick's Avatar
rocketrick
Cruising
so I look up my leather seat . com ?
Old Apr 4, 2016 | 08:29 PM
antfarmer2's Avatar
antfarmer2
No click on my name then click on threads started by me then look at my seat post. I paid $249 the last guy got them for under $200
Old Apr 4, 2016 | 08:48 PM
  #33
rocketrick's Avatar
rocketrick
Cruising
ok when I click on your name I get choices of looking at your profile n making you a contact n such but do not see a thread
Old Apr 4, 2016 | 09:02 PM
  #34
antfarmer2's Avatar
antfarmer2
Click on my profile then statistics then threads started by me.
Old May 23, 2016 | 09:35 PM
  #35
rocketrick's Avatar
rocketrick
Cruising
ok does anyone have a recommendation for a good clutch kit and flywheel
Old May 23, 2016 | 09:41 PM
  #36
antfarmer2's Avatar
antfarmer2
Did you fix your over heating? Best to start a new thread for your clutch.
Old May 23, 2016 | 09:42 PM
  #37
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
start new thread!
To overheating
Old May 23, 2016 | 10:03 PM
  #38
rocketrick's Avatar
rocketrick
Cruising
Default overheating
well kinda I put a 160 degree stat in and its a lot better
Old May 23, 2016 | 10:34 PM
  #39
mtwoolford's Avatar
mtwoolford
I surmise that your water pump is "cavitating" at high rpm, which severely disrupts coolant flow...get a new high flow water pump...and don't cheap out here, make sure it has a curved vane machined impeller, a stamped sheet metal "paddle wheel" style impeller won't cut it for your application.
and I have had, strange as it may seem, new name brand thermos stats that were defective.
Old May 23, 2016 | 11:06 PM
  #40
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
dido.
jack front passenger side highest. i actually just park diagonal on a steep driveway now. easier.
with my passenger front corner higher up, here is what i do:
fill overflow container to half way between cold and hot markings.
fill rad.
keep cap off.
start car.
keep the coolant topped up. at about 80deg C,
suddenly there is going to be a drop in the coolant level. you will also see the "waterfalling" occur. this is because the thermostat, which acts like a dam in a river, just opened its doors and allowed the water to flow in a circut. but, be careful, u dont want to dilly dally with the cap off.
keep it topped off and once its steadily full at idle, now reach over with your left hand and get rpms up using your fingers to move the throttle body. you will see the coolant get sucked in/down: the fluid level will drop, as the engine is revving high, say 2000rpm, pour in more coolant.
with rpm still high, set down the cookant bottle and put the cap on the rad. then u can stop revving.
now shut off the car, and let it cool. check thr overflow reservoir.
