Installing head bolts
Old Feb 26, 2016 | 04:19 PM
skidball's Avatar
skidball
Default Installing head bolts
I have the bolts with factory sealant on them. They say no sealant or lubrication needed ? Would you guys oil or spray the bolts anyway ? Sat. Project.
Old Feb 26, 2016 | 04:22 PM
skidball's Avatar
skidball
Default Water pump question.
While I have the car drained of coolant. Should I check the shaft bearing seal on water pump. Could it leak coolant into engine ? Or what ?
Old Feb 26, 2016 | 05:04 PM
John A. Marker's Avatar
John A. Marker
A reminder.....always include the year of your car.
No other lubricant on the head bolts. You should chase the threads in the block to be sure they are clean.
LT car?? Should not leak coolant into the block.
Old Feb 26, 2016 | 09:07 PM
HAD2HAV2's Avatar
HAD2HAV2
No other lubricant on the head bolts. You should chase the threads in the block to be sure they are clean. J.A.M is correct (to use his quote).
Old Feb 27, 2016 | 06:20 AM
skidball's Avatar
skidball
Default Thanks.
Yes I chased the threads, What a difference. 92 lt1.
To Installing head bolts
