Headlights
Old Mar 15, 2016 | 02:35 PM
monte k's Avatar
monte k
Default Headlights
I just replaced the gears in the headlights on my 84 c4 corvette
Is there a I info on adjusting where they will stop when they open and close
Or is that something that's preset someplace
Monte
Anderson , IN
Old Mar 15, 2016 | 02:58 PM
Hot Rod Roy's Avatar
Hot Rod Roy
The open and close limits are determined by the adjustable stop screws on the brackets for the headlight doors. When the doors hit these stop screws, the motors detect the increased load on the motors as they stall out. The limit switches inside the motors then open the electrical circuits for the motors, which turns off the motors.
(This is for the '84-'87 headlight operation only)
Old Mar 15, 2016 | 03:12 PM
monte k's Avatar
monte k
Default Headlights
Hello
Thanks for the info
Monte
QUOTE=Hot Rod Roy;1591778132]The open and close limits are determined by the adjustable stop screws on the brackets for the headlight doors. When the doors hit these stop screws, the motors detect the increased load on the motors as they stall out. The limit switches inside the motors then open the electrical circuits for the motors, which turns off the motors.
[/QUOTE]
Old Mar 16, 2016 | 12:23 AM
Cliff Harris's Avatar
Cliff Harris
There are two stops that determine where the headlight door ends up at the limits of opening and closing.
The closed limit stop:
The open limit stop:
Old Mar 16, 2016 | 06:38 AM
monte k's Avatar
monte k
Default Headlights
Hello, thanks for the reply that's what I'm looking for
monte
To Headlights
