I have a c4 corvette 1984 71000 miles with manual tranny and no reverse lights . does ay one know if there is a switch on transmission or somewhere else?
Yes there is a switch on the transmission that should close when in reverse. There is also a fuse in the passenger side fuse panel. Sometimes a switch will short and blow the fuse, in which case you'd need both.
thank you for your response! would you know where it might be located on the transmission? tail bell housing?
The picture said specifically 84 4+3 Corvette. I looked up again and found several places that says this one is the correct one. I edited my earlier post.The picture above shows you where it is located so you can check your plug and connections. If you put the transmission in reverse with the plug disconnected you should read almost zero ohms between the two contacts on the transmission side where switch screws in. Again, check the fuse first.
Driver's side about center:
The picture said specifically 84 4+3 Corvette. I looked up again and found several places that says this is the correct one. I edited my earlier post.The picture above shows you where it is located so you can check your plug and connections. If you put the transmission in reverse with the plug disconnected you should read almost zero ohms between the two contacts on the transmission side where switch screws in. Again, check the fuse first.
Your the best!!!! I will check the fuse and again thank you for all your very helpful info!!!
Well I can tell you that maybe you should give up "window shopping" or using "window shopping" images as references. Use any of your shopping sources and the correct GM # 14057528 and if they show your image I'd be interested to see it. It would be a vendor to very likely to avoid.
OP - the switch is very likely available at your "local" auto parts store using the information (GM part #) as a reference. Auto Zone or Oreilly potentially, NAPA very likely but theirs looks expensive maybe.
I can assure you the "link" I provided is correct for a visual image.
"65GGvert" - This is your first posted image, you only needed to mention a "ooops" (ZF Switch) and maybe post you new "best guess" along side what you insisted was correct. You've certainly done better the 2nd visit to a manufacturer using the part number I supplied or the SMP catalog.
OP - most detent-ball operated switches usually become lazy/inoperable because of lack of use, I like to call it "exercise". Generally speaking if you have time just remove yours and soak it for some time in solvent and exercise the "ball" several times during the soak. You can confirm operation using a DMM after the soak/exercise operation. That was always our "first choice" for any detent-ball switch. I've never had a "soak/exercise" fail on a ZF switch.
I didn't use anything of yours, I merely posted the wrong picture first and corrected it. The difference in my post and yours is I was trying to help the guy find his reverse light switch, while you are trying successfully to be a jerk.
I don't have an 84, but it appears from research that the turn signal and b/u lights are on the same fuse, so if turns work it won't be the problem. In case anybody asks, the following picture is not from my personal pictures, but is represented as an 84:
It was only a couple more snapshots so I thought I'd just finish this:
"65GGvert" posted an incorrect image but here's the FUSE BOX, the wiring diagram and the diagnostics. His mention of "if you have directional that work it's NOT the fuse is correct".
If anyone has an '84 and needs wiring diagrams here's a zip-file from the CAC that has them all, it's well done and I've checked most of it against an '84 FSM. No diagnostics just diagrams.
