1989 Convertible a/c problem
Old Mar 21, 2016 | 10:24 PM
JD Junior's Avatar
JD Junior
Navigator
Default 1989 Convertible a/c problem
Hey everybody, new to the forum, my heat & air work fine but the digital temp & fan speed display for the a/c isn't illuminated anymore & the setting indicator as well! Any ideas what to check ? Thanks!!
Old Mar 22, 2016 | 05:22 AM
Cliff Harris's Avatar
Cliff Harris
Does the radio light up? It's on the same circuit as the HVAC lighting. You might have a burned out bulb.
Old Mar 22, 2016 | 07:39 AM
JD Junior's Avatar
JD Junior
Navigator
Thanks for responding! Yes my radio light is on! I will also add that prior to the display light failure I had noticed it going off & coming back on sometimes! My guess is a short in the wiring ?
Old Mar 23, 2016 | 01:07 AM
Cliff Harris
More likely a bad connection in/at the bulb socket.
Old Mar 23, 2016 | 07:49 AM
JD Junior's Avatar
JD Junior
Navigator
Thanks Friend! That's where I'll start!
To 1989 Convertible a/c problem
