auto door locks
Old Sep 4, 2002 | 10:14 AM
halver's Avatar
halver
Default auto door locks
1988-vert locks don't work, both sides fuse ok, am i missing something?
Old Sep 4, 2002 | 02:14 PM
Charlutz's Avatar
Charlutz
Default Re: auto door locks (halver)
sounds like a fuse, but if you've eliminated that as a possibility, not sure. did they stop working at the same time? both of mine stopped working, but it was at slightly different times so i knew the problem was specific to each. ended up being loose connections inside each door (y'know that rattle in there could be unconnected wires flapping around!) when i replaced my radio and had the door panels off i reconnected and tightened up all the wiring and now they work flawlessly. you could give it a shot, but it does sound like your problem is systemic, rather than specific to the door connections.
