Removing Tree Sap
Old Sep 4, 2002 | 12:29 PM
jmr302's Avatar
jmr302
Default Removing Tree Sap
Dangit! I hate it when this happens. Do you guys know any tricks for removing dried-on tree sap? I've already tried Brakleen and Simple Green. Smeared it around a little bit but the bulk of it is still there and not budging.
Old Sep 4, 2002 | 01:01 PM
Paul G's Avatar
Paul G
Default Re: Removing Tree Sap (jmr302)
I have a spray bottle of Tar and tree sap remover. Turtle wax makes it I think. It works pretty decent. Other than that you can try polishing compound for clear coat. That will remove just about anything including the clear if you get to crazy with it.
Old Sep 4, 2002 | 01:08 PM
TrplBlk01's Avatar
TrplBlk01
Clay bar and some wax and grease remover or bug and tar remover.
Old Sep 4, 2002 | 02:06 PM
Kei28's Avatar
Kei28
Default Re: Removing Tree Sap (blk91)
WD-40
Old Sep 4, 2002 | 04:14 PM
c4cruiser's Avatar
c4cruiser
Default Re: Removing Tree Sap (Kei28)
Another vote for WD-40. I keep one of those 3 oz. bottles in the car for road tar, bugs and tree sap.
Old Sep 4, 2002 | 04:41 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Default Re: Removing Tree Sap (c4cruiser)
Is WD40 actually safe for paint? I have a few nasty tree sap blobs to remove from my hood this weekend.
I know laquer thinner will instantly remove sap but I am not about to put that on my paint. I used the Turtle Wax remover but it seemed to take forever to work.
Old Sep 4, 2002 | 04:47 PM
TrplBlk01's Avatar
TrplBlk01
Default Re: Removing Tree Sap (Professor)
It works well to get it off but if you ever need to paint that area :lol: :cry
There is a world of hurt wainting for the paint shop!
Old Sep 4, 2002 | 04:56 PM
92TripleBlack's Avatar
92TripleBlack
Don't forget to remove the offending tree. :smash:
Old Sep 4, 2002 | 05:39 PM
Cap'n Rich's Avatar
Cap'n Rich
Mineral spirits (a.k.a. paint thinner, Stoddard solvent).
Rich
Old Sep 4, 2002 | 05:41 PM
webs92's Avatar
webs92
Default Re: Removing Tree Sap (Paul G)
I use the tar and tree sap remover by turtle wax also. Works like a charm. I actually just used it this weekend.
Old Sep 4, 2002 | 06:08 PM
1bad85's Avatar
1bad85
From: livin life one hold my beer moment at a time Houst Tx
Default Re: Removing Tree Sap (webs92)
Brake fluid. :D
nono dont use brake fluid, just kidding. But hey, paint thinner sounds good.
Old Sep 4, 2002 | 09:10 PM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
I just read in a local newspaper auto column that turpentine is the ticket! Now I hadn't tried it! Not sure I spelled it right but, according to the writer it's the right stuff! I would read the label too before purchasing!
I've used Blue Coral and it's pretty effective. Because the sap is so dry, I would soak a rag with the Blue Coral lay in on the sap for 20 to 30 minutes and then try to remove with a soaked rag. Several applications may be necessary, but don't rush it.
Good Luck!
Old Sep 6, 2002 | 02:06 AM
Dan Parker '96's Avatar
Dan Parker '96
I'm sure solvents will do the trick. But I just finished off my RSX with a clay bar and was thoroughly impressed. I still need to do some research on why it's so effective, but it did do the job quite well. I'd recommend it.
To Removing Tree Sap
