Opti- Spark (1992)
Opti- Spark (1992)
Just had my opti-spark replaced again. Symptoms were the engine would die whenever it chose to. Originally started right back up, but as it got worse, the re-start became more & more difficult.
My question is: When mechanic ordered part according to my vin, he received the wrong unit (no shaft) They ended up getting an opti-spark for a twin overhead cam engine & that was correct.
Any thoughts why?
Any thoughts why?
Any thoughts why?
Any thoughts why?
Received 7,028 Likes
2015 C2 of Year Finalist
somethings not right. there is only two opti a non vented 92-94 and a vented 95-97.
Pro Mechanic
Our Dodge Stealth RT/TT (remember those?) had an "Opti"...and DOHC....but no way would that one, fit and work or be "correct" on a Chevy motor. That Mitsubishi motor was the only DOHC motor that I'm aware of that had an "Opti".
I remember them well. I had a couple friends who had several. The Mitsubishi "optical sensor" theoretically is modified by many for other than applications using the optical - it was used on many early/mid '90s other than the 3000/Stealth RT.
My thoughts are they felt compelled to tell you something besides the truth. Probably because if you knew the truth they would be very embarrassed. I wouldn't let it bother you though as long as the car runs properly when you get it back and they charge whatever they quoted.
