Throttle Body?
Old Apr 8, 2016 | 01:10 AM
PsarosJake's Avatar
PsarosJake
Default Throttle Body?
Thinking about bundling these three parts together. 1. A 58mm BBK throttle body <-- Dont know why this is a link. 2. An Corvette TPI airfoil flow booster 3. An induction front power coupler... Thoughts on if I should put these on my 1994 C4 Vette?
Or are these all china crap parts that won't do anything for my car.
Old Apr 8, 2016 | 08:26 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
You answered your own question.
Old Apr 8, 2016 | 11:53 AM
THE 383 admiral's Avatar
THE 383 admiral
The Quality BBK TB & similar already have that Un-safe bolt-on. Air-foil. Built in the casting. It would not be worth spending $290 - up. You would feel a better throttle response. But to be honest really would need a tune adjustment to match the now higher air flow. Unless it was installed on your car when purchased. "free" OR you have plans for more performance part's. upgrade your exhaust.
Old Apr 8, 2016 | 12:55 PM
Dr.Dumas's Avatar
Dr.Dumas
I put an air foil on a 1989 IROC Z with the 5.7 (TPI) in it and I liked what it did. It seemed to make the car start easier, maybe smoother is the word. It also took off from a stop smoother. Did it add 25HP? I really don't think so but I liked what it did to the drive-ability of the car. When I sold the IROC I gave the air foil to my brother in law who had a C4 and he found the same results I did. It's on the list to add to the 92 I am bringing back from the dead.
Old Apr 8, 2016 | 01:06 PM
John A. Marker's Avatar
John A. Marker
Air foil adds zero HP. Not worth the money. This should have no effect on starting or leaving from a dead stop. You might have just knocked out some carbon deposit in the TB when you installed it.
Placebo effect........ Pasr Forum members have installed and dynoed with no positive or negative results other than their wallet was lighter.
Old Apr 8, 2016 | 01:07 PM
THE 383 admiral
Sorry. That air foil would have nothing to do with Starting! and will Not add even 5HP. many have had the nut back out! and there engine now inhaled. Ought Ohhh.
Old Apr 8, 2016 | 01:31 PM
THE 383 admiral
FWIW,
a air flow chart.
http://www.hobracing.com/tech/tpi_flow.asp
Old Apr 8, 2016 | 02:43 PM
antfarmer2's Avatar
antfarmer2
Take half the money you just saved and donate it to the forum.
Old Apr 9, 2016 | 01:29 AM
aklim's Avatar
aklim
You will feel faster from the placebo effect and your wallet will be lighter. If you want to save on labor, give me the money for the parts and be happy.
Old Apr 9, 2016 | 01:31 AM
aklim's Avatar
aklim
Google Placebo effect. I had a friend that felt the 1000 cfm TB made his car faster. There was only one minor problem, Each run he made with it was slower than the ones with the stock TB. It did feel faster though.
Old Apr 9, 2016 | 01:32 AM
aklim's Avatar
aklim
Originally Posted by bow tie guy
only if you install an aftermarket intake system in place of the poorly engineered OEM, will these performance mods make a difference
you definately want to run seafoam first, then plasti-dip the wheels black
I disagree. You seafoam the wheels and run plasti-dip in the engine.
Old Apr 9, 2016 | 01:54 PM
Klondike's Avatar
Klondike
I've got one of the plastic airfoils in my throttle body intake. It fits very well to the stock 48mm throttle body, and the air cleaner pipe fits snuggly right over it. Does it work?, beats me! It was on the car when I got it and it runs just fine so I left it alone.
58mm throttle body is a waste of your money unless you have a really built 383. It's just WAY too big. The LT1 won't flow very much more than the 48mm will supply any way. You might see a slight improvement with a 52mm but after that, it won't flow any more than if you just took the thing off the manifold completely. The seat of the pants thing that people feel is when the engine finally gets past the huge bog and starts pulling. By that time, the stock throttle body would have you a lot farther down the road.
Old Apr 10, 2016 | 09:14 AM
jts90vette's Avatar
jts90vette
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
Don't waste your money! You wont see/feel any difference.
Old Apr 10, 2016 | 09:43 AM
aklim's Avatar
aklim
The placebo effects would disagree
To Throttle Body?
