Drags trip time
Old Apr 9, 2016 | 06:39 AM
JD1964's Avatar
JD1964
Default Drag strip time
Last time we couldn't break into the 12's but this time we did. Second best was 13.08 at 108. Here's the best slip of 12.88 at 110. <br >
Old Apr 9, 2016 | 06:46 AM
JD1964's Avatar
JD1964
Heres the thread from the previous trip. Only thing different this most recent time out was we dropped the spare and jack and the driver was 30lbs lighter.
https://www.corvetteforum.com/forums/c4-general-discussion/3717614-test-n-tune.html
Old Apr 9, 2016 | 07:49 AM
1stVetteFinally's Avatar
1stVetteFinally
Me last night with major traction issues-
All stock '92 coupe with auto. It was cold (low 50'ties), I didn't have my track tires, and the track was slick as hell. If I could of got it to actually hook up, I would have been in the high 13's.
Old Apr 9, 2016 | 08:09 AM
ghoastrider1's Avatar
ghoastrider1
congrats guys, isn't the 1/4 a hoot to race. My L-98 is bone stock. My best so far is 14.037 at just over 97 mph. My big problem is also traction. Anything above idle is a wasted effort and even off idle it just spins to much. Like you guys, I gotta get a set of drag radials. I WANT in the 13s.
Old Apr 9, 2016 | 08:22 AM
JD1964's Avatar
JD1964
I have Nitto 555 street tires (not drag radials). I have no traction problems at all. The tires I had before (same stock size) still had good tread but they were dated and the rubber was getting harder with time. Those tires spun like crazy. Amazing what a new set of softer rubber will do for traction improvement.
Old Apr 9, 2016 | 09:04 AM
PatternDayTrader's Avatar
PatternDayTrader
So I'm sure I understand. You ran the 12.88 on nitto 555 ???
Old Apr 9, 2016 | 11:07 AM
JD1964's Avatar
JD1964
Yes, with stock tire pressure and only a mild burnout just enough to dry the tires after the roll through the water box.
Old Apr 9, 2016 | 11:10 AM
JD1964's Avatar
JD1964
NT 555 Extreme Performance, to be exact.
Old Apr 9, 2016 | 11:12 AM
1993C4LT1's Avatar
1993C4LT1
That's a really good time. Your car is stock?
Old Apr 9, 2016 | 11:50 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nice times! Car is a strong runner. I'm headed to the drag track this afternoon...first one of the year, here in UT.
Old Apr 9, 2016 | 11:59 AM
1993C4LT1's Avatar
1993C4LT1
Post up your ET!
Old Apr 9, 2016 | 12:14 PM
JD1964's Avatar
JD1964
Not stock. Moderate aftermarket cam, 3.54 rear gear, PCM tune. All else stock. Except for the Cray wheels which are actually heavier than the stock saw blades. I'd have a higher trap speed if I put the stock wheels back on.
Old Apr 9, 2016 | 01:43 PM
1stVetteFinally
Nitto 555 are good tires, had a set on the car when I got it. I'm running 295/35/19 Hankook Ventus V12 on the back of my car for street driving, and they are about to the point of not passing inspection. I have NT05 tires I normally run when I go to the track.
Old Apr 9, 2016 | 02:25 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Post up your ET!
I shall. I'm expecting high 13's/~100, but keep in mind my elevation. Car is stock. I'll post results tonight.
Old Apr 9, 2016 | 03:29 PM
ghoastrider1
John, that's a pretty good RT. My best so far has been .350. The Indy track isn't open yet but I believe it does this month. Best of luck Tom and hope all stays together.
Old Apr 9, 2016 | 03:42 PM
1993C4LT1's Avatar
1993C4LT1
Old Apr 9, 2016 | 03:51 PM
trilkb's Avatar
trilkb
RT doesnt really matter on a test and tune night. Ive had some lower then that and im by no means experienced, just got lucky.
So your running stock exhaust manifolds? stock rockers? just the "mild" cam?
Still good times, fast enough to not look like a fool against a c5!
To Drags trip time
Old Apr 9, 2016 | 04:11 PM
1stVetteFinally
I was turning 14-14.2 @ 101-102 mph. High 13's, you should be in the 104-105 mph range. Good luck and have fun. Looking forward to seeing your results.
Old Apr 9, 2016 | 04:25 PM
JD1964's Avatar
JD1964
The 12.88 is actully my son's run. We both drove it that night. He ran quicker than me and also had better reaction times. I was a habitual red lighter. LOL
Old Apr 9, 2016 | 04:29 PM
JD1964's Avatar
JD1964
Thanks for poking me on this. I missed listing aftermarket roller rockers, valve springs and push rods. I guess I was considering those as cam related. I did reuse the stock roller lifters.
Completely stock heads and stock exhaust including stock cats. Muffler eliminators for good sound but they dont add performance.
