I'm in the market for a C4. In the past few weeks I've seen my share of some beautiful cars. A few of the C4's looked like the rear was a little more off the ground than others. It was noticeable by the space from the top of the tire to the top of the wheel well opening. The tire size was the correct factory specs as all of them. Can the height be adjusted the same as a C5????
On a "stock" car the bolts at the ends of the springs are something very near 9" long. To "LOWER" the car you lengthen those bolts, it's customary not to exceed 11" I believe. Size matters, the OE are M14 and most use a more readily available 9/16 SAE thread and a comparable castellated nut or a ny-lock.
If you lower the rear of the C4 you affect the aerodynamics in a negative way. The slight rake in the body is part of the design that creates down force at higher speeds.
I lowered the rear of mine a little with longer spring bolts to get my car to sit more level. It had the added benefit of levering the nose off the ground a little so I don't drag the air dam in the driveway now.
I like the lowered look on the C4. What wheels do you have on yours??
The wheels are ZR-1 replica's 17 x 9.5
That is all that I have done also.
Replaced the factory bolts in the rear with longer ones.
Similar to these.
I think the rear ride height also depends on the spring rate.
Stiffer springs increase their rate more quickly as they compress, and will support the same weight over a shorter suspension travel distance, if that makes sense. So, stiffer springs allow a car to sit lower without issues. Same goes when tuning suspension -- you don't want to lower the suspension too much without stiffening the springs or your chassis may scrape the ground or tires will rub the wheel wells, or other issues.
The same car with softer springs will ride a little higher, this extra distance allows them to reach the same spring rate over a longer distance, because they are softer.
Maybe I'm not explaining this right, but I think someone will pick up what I'm laying down.
Thanks for the help. Much appreciated :-) I did buy the car today. I'll get more in to the height next week. It looks pretty good in person.
