Quick question about convertible hard tops
PM me if you need to retrofit to an older Vette and I can help you out.
There is a company called Smoothline that makes one to fit all C4 verts but they do not incorporate a factory roll bar like the OEM has.
My old 87:
Looking at the pics of the top, I see that it has the front mouting hardware in the 89-96 targa top triangle shape hardware. Does my convertible have the screws inside the header panel that will go into this top? I am used to the pull style levers the soft tops have.
Brackets and bolts.
Rear hardware, may be mounted to top.
Torx wrench.
Wrench for rear bolts, not factory, but you get the idea.
I love the hardtop on our 89, really stiffens the car up makes it a year round driver.
Thanks so much for the pics! So here is the question, if the seller does not have the brackets for the back, how hard are they to get? Can the top be mounted and then safely transported at highway speeds without them?
The GM hardtop was designed with a "halo bar" inside it (just like the coupes have) so that when it was properly installed, the convertible body was actually stiffer than the coupe body. The connecting brackets tied the B-pillars together and the convertibles has the undercar X-brace that was not on the coupe
The windshield header mounting brackets do have to match what is on the hardtop. The brackets on the rear decklid have to be able to allow the hardtop locating pins to drop in and the decklid brackets have to have the welded nut on them to allow the rear pins to screw into place.
I would advise not to install a GM hardtop on the earlier cars where the only attaching points are the windshield header and the decklid latches. Without the B-pillar brackets in place, the convertible body could flex to the point where the decklid latches could twist and break the decklid. The GM hardtop weighs about 65 lbs.
For your '96. a factory GM hardtop will work. The windshield header screws should already be there. Same with the decklid latches; they will have that nut welded in.
The hardtop also has a defogger built into it, but IIRC, you need to do some wiring to get it to work. There is a hot wire under the carpet near the passenger side shoulder belt mount tower. A ground wire will have to be made and it installs near the driver's side shoulder belt tower. The owner's manual should have instruction on the operation.
I really liked having a hardtop on my old '92 'vert. Exhaust resonance went away and the car was free of squeaks and rattles. Getting stuff in and out of the rear storage area was a PITA tho.....
