check engine light
Old Apr 18, 2016 | 09:38 AM
mickey5's Avatar
mickey5
Default check engine light
My '90 L98 is showing the check engine light. I took it to the auto store to retrieve the codes but they tell me they can't check the OBD 1 system. Youtube shows how to do it by putting a paperclip between the A and B computer connector terminals under the drivers dash and reading the pulses in the DIC. Does this really work? I don't want to hurt anything. Please advise.
Old Apr 18, 2016 | 09:51 AM
c4cruiser's Avatar
c4cruiser
The "paperclip method" does work for pulling OBD1 codes.
With the ignition OFF, bend a paperclip and insert the ends in terminals A and B.
Turn the ignition to ON (don't start the engine) and watch the CEL flash. You probably saw how the series flashes work from the Youtube video. Remember that a Code 12 (one blink, then two, repeated two more times) is both the start of the trouble codes and the end. As long as the ignition is ON, the entire sequence of codes will repeat over and over.
Old Apr 18, 2016 | 10:18 AM
John A. Marker's Avatar
John A. Marker
c4cruiser has if correct. Write down the code(s). You can look on the next for the meaning....which will direct you to a system to check out.
To check engine light
