Replace Resonator or X Pipe 1996 CE LT1
Old Apr 30, 2016 | 10:38 PM
toricred's Avatar
toricred
Default Replace Resonator or X Pipe 1996 CE LT1
1996 CE LT1 Totally Stock:
In the last few days my exhaust has gotten much louder and the drone is back (I almost eliminated it earlier by going to stock mufflers). I can feel a rumble under the driver's seat that wasn't there before I'm guessing something has gone wrong with the resonator (it's the original).
I don't want to go much louder and I really want to eliminate that stupid drone. I don't have the money for a cat back system or Corsa. I've been trying to just find a replacement resonator, but I want something new so I don't end up in the same place. I haven't been able to find one, but it sounds like an X Pipe might be better anyway. Would an X Pipe really help eliminate the drone? What would be the best place to get either that would fit the stock exhaust?
Old Apr 30, 2016 | 11:10 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
To the best of my knowledge there are only two systems that do not produce drone on your stock 96 LT1.
They are the stock cat back system that came on the corvette and the complete corsa system.
There are plenty of the stock ones around. If you have replaced the center resonator once without success, I urge you to try to locate another one. You need the stock resonator and the stock mufflers.
Old Apr 30, 2016 | 11:16 PM
toricred's Avatar
toricred
When I bought the car it had the mufflers completely eliminated and I put back stock mufflers, but I have never replaced the resonator. I haven't actually found a place to get one. Do you know where I could get it? I'm in the middle of nowhere with no junk yards around so they're not an option.
Old Apr 30, 2016 | 11:28 PM
Mr. Peabody
Well first it would really help if you filled out your profile and told us where you are. That way if there turns out to be someone that knows someone that knows someone who's not too far from you....
Unfortunately, the central resonator is not a part that is sold separately. There are however many people on the parts for sale section of the forum that offer their stock exhaust to anyone will pay to have it shipped. the one thing that goes to your advantage is that if you find someone with the stock exhaust system just ask them to saw the pipes off of the resonator leaving 1" stubs on each end. It's much less expensive to ship just the resonator that way. Then you can have a muffler shop weld it up for you.
You might try www.vette2vette.com
Old Apr 30, 2016 | 11:32 PM
toricred's Avatar
toricred
I didn't realize I hadn't filled the profile out. Thanks for pointing that out.
I live in Los Alamos, NM so shipping will be a bear, but if I can find one for less than a Corsa system then it will be worth it.
Old May 1, 2016 | 03:31 AM
Klondike's Avatar
Klondike
I've heard a couple of people that took out the resonator and welded in a pair of long tube glass pack or steel pack mufflers in place with an H pipe in front and done away with the drone. I've never heard one myself, but it seems like something a muffler shop could do.
Old May 1, 2016 | 02:22 PM
Paul Workman's Avatar
Paul Workman
An "X" pipe will NOT get rid of drone. a stock 95 or 96 resonator w/ mufflers and cats are quite good. And, Magnaflow's resonator worked quite well - far as drone went (on my Z).
IIRC, the complete cat-back Magnaflow for the C4 was around $800 ish, about 5 years ago.
Good luck tho on the 96 resonator. That, with the mufflers was drone free and actually flowed quite well!
Old May 1, 2016 | 03:52 PM
jay1055's Avatar
jay1055
I sent you a pm last night about my 93 complete stock cat back located in Albuquerque probably cheaper than the resonator. Jay
Old May 1, 2016 | 04:55 PM
toricred's Avatar
toricred
I just saw that. I think I'm interested, but is the 93 exhaust system the same as the 96? If so, how much do you want for it?
Old May 1, 2016 | 06:37 PM
jay1055's Avatar
jay1055
Default Exhaust
I believe it will fit but not positive is $150 a fair price picked up? Jay
Old May 1, 2016 | 10:00 PM
toricred's Avatar
toricred
It doesn't sound as fair as $100 , but that should be good. I looked it up and it appears that the 93 stock should fit on the 96. I won't be in Albuquerque for couple of weeks (probably 5/14/16). Would that work for you?
Old May 1, 2016 | 10:06 PM
jay1055's Avatar
jay1055
Default Exhaust
14th works for me just keep me updated so I can take it down and this is all in 1 piece so you will need a pickup. Jay
Old May 1, 2016 | 10:08 PM
toricred's Avatar
toricred
The truck may take me an extra week. It's in need of a new alternator at the moment and I may not get to it next weekend. At worst it will be the 21st. I'll let you know at least a week in advance.
Old May 1, 2016 | 10:14 PM
jay1055's Avatar
jay1055
Default Exhaust
Thanx a weeks notice will give me time to get it down from hanging from the ceiling
Old May 14, 2016 | 06:22 PM
toricred's Avatar
toricred
So reading the forums I just saw that a 96 needs an extra bung for an O2 sensor that previous years don't have. My normal mechanic doesn't do welding and neither do I. I'm checking out a new mechanic Monday and I'll ask him about the options.
To Replace Resonator or X Pipe 1996 CE LT1
