rear window removal
Old May 5, 2016 | 02:41 PM
88JDO's Avatar
88JDO
Default rear window removal
What is the best way to remove round black nuts holding back window to hinge assembly? Do I just break the window?
Old May 5, 2016 | 06:28 PM
antfarmer2's Avatar
antfarmer2
That would be one way but sounds messy why do you want them off?
Old May 5, 2016 | 07:05 PM
88JDO's Avatar
88JDO
I have a replacement because my 20 year old tint is purple. I have the nuts off, a blast of penetrating oil and needle nose pliers to twist them off. The problem now is breaking the sealant between the glass and the hinge assembly.
Old May 5, 2016 | 07:25 PM
antfarmer2's Avatar
antfarmer2
You will most likely break the window solving your tint problem. Try this spray the tint with 409 cleaner many stores sell it just a household cleaner. Spray it on the tint then wrap in black plastic and let it sit in the sun repeat if needed. If you want to break it I would remove it from the car from the halo.
To rear window removal
