I have a 92 coupe and I have C5 thinspokes on now but the rear 18" wheels do not fit like the oem 17" did. I would like to know what size spacer I need to get the right stance.
C4 and C5 have the same off set. The tire diameter of the 18 is one inch taller. You could lowering bolts to drop rear of car, to compensate for taller tire.
The offset difference is 9 mm. That would make them fit the same position as the OEM C4 17" x 9.5" wheels.
However, that is an odd spacer size due to lug studs. It is a little too much for just using a spacer without adding longer lugs, and an adapter will have the studs stick through them so that the wheel may hit them and not fit without shortening the studs.
I would use a 19mm adapter/spacer and that would "boost" the rears 10mm further "outboard" than your original 9.5 @ 56mm. That would be a very satisfactory appearance for a C4 and still be well within the wheelhouse. I suggested 19mm because it's a readily available "on the shelf" from most suppliers.
The thin-spokes I'm quite sure have a recess between the stud holes so there should be no issues.
I have found adaptec has spacers in 7mm(1/4") or 10mm(3/8") and would like to know if the studs would be long enough to safely work for this small of a spacer?
I don't believe the wheel-studs will accommodate the spacer. You could buy a stack of washers and see just how much the studs would accommodate. Stack washers on three studs and bolt a wheel/tire on to see if that makes you happy.
I really believe the 19mm adapter/spacer would make you happier after done.
Check one of the C5 wheels for the recesses between wheel stud holes.
Another thing to consider is that the spacer (both but certainly the 10mm) will use nearly all of the bearing hub dimension that makes the wheels hub-centric to the car. You'll loose that feature because the wheel center-bore is actually a taper for the first few mm.
