Performance Upgrades
Old May 31, 2016 | 09:05 PM
  #41
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by bow tie guy
you've heard of fecestious puns? "REVERSE FLOW COOLING" is just that
I heard Tom's C4 has Dual "Hot" air bags
A sarcastic reply is a common response when challenged to produce facts. Good one.
Old May 31, 2016 | 09:27 PM
  #42
PatternDayTrader's Avatar
PatternDayTrader
Originally Posted by Tom400CFI
But the filter is inside...the engine compartment. Inside. This isn't hard to see with eyes.
No one was debating the location of the filter. Obviously its inside the engine compartment, and its positioned in such a way as to draw air from outside the engine compartment. This should not be a surprise since just about every fuel injected car is designed to obstruct water and road debris but allow cold air into the inlet. Just say something acknowledging that the pic of airflow posted by Aardwolf has changed your mind and if its in fact correct that your willing to accept it as truth. There is nothing wrong with that, since the best way to be right about something is to stop being wrong. You know good and well I certainly would.
Old May 31, 2016 | 09:40 PM
  #43
bow tie guy's Avatar
bow tie guy
Default ad nauseam it is
84Z51J
Set aside your ego for a moment, open your mind, and realize I've been trying to help you learn something, not show the world how wrong you are. There is nothing wrong with ignorance, until it becomes willful, which frustrates me to no end.
84Z51J
the facts were presented to you, and you choose to ignore them
these are the facts Tom:
Cold air is introduced through the 18 louvers in the air box' lid, cold air from under the bumper enters in front of the air box through an opening approx 8" wide
if you look below the emblem that says "Bowling green kentucky" you will see this opening
also, the fact that cold air enters the air box was pointed out to you by Aardwolf when he informed you that IAT's were 1 degree above ambient not the 35-40 you claimed
you also were provided a thermal photo that clearly demonstrates that no hot air can back flow through the radiator and or a/c condensor to the air boxes inlet in a heated state
again I ask How does Hot under air from the hot semi sealed under hood area get to to air boxes louvered inlet
You going to answer me or stand there with a slack jaw
here's a pic of the opening in front of the air box louvers
note the tape measure opening is in the center of the scale
I put a shop light under the bumper and you can see light shining through the opening
Ardwolf says air comes through the fog lights and gaps
I'm telling you it comes from in front of the air filter's louvers
Old May 31, 2016 | 09:47 PM
  #44
PatternDayTrader
This is truly a sentinel moment for ole Tom. I'm betting he's man enough to change his mind, however distasteful it may be.
Old Jun 1, 2016 | 12:02 AM
  #45
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I'm happy to admit I'm wrong...done it many times. When someone can and will present something concrete. A picture of a cut out in the radiator shroud, for AC tubes, isn't that.
Guys, as always, I like to seek the facts. I prefer to explore and find answers, rather than resorting to deflection and insults. To that end, here is what I'm going to do; I'm going to use my DVOM with it's temp probe, to measure temps at various places under the hood. I'll post the results of each location. That is objective data, and indeed, I may very learn from that experiment, that ambient air is directed very deliberately into the air filter. I don't think that is what I'll find, since the filter is sitting in s pretty unventilated area...inside the engine bay...but objective data will tell the story. I think that most reasonable people would agree that pursuing things this way, is better than avoiding the facts and throwing insults.
Old Jun 1, 2016 | 12:06 AM
  #46
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I've looked there a million times...I don't see that opening. Aardwolf has a different car than I do; I believe that his has the earlier cooling package w/the forward leaning radiator. He posted pics of his radiator shroud that don't look like my car. So...he might have the results he claimed. I didn't dispute his results. He did, after all post objective data. Something you've not done.
Easy. It is drawn there from the dotted area above the radiator, by the ingestion of air through the filter. IDK WHAT that pic is that Aardwolf supplied. You call it a thermal photo. Maybe it is; the air changes temp as it rises over the hood? Maybe it does...but IDK why it would. Do you? Anyway, to ME it looks more like a image depicting WHERE and HOW MUCH air flows, inside the front of the car. It looks like most is flowing through the radiator -as one might expect. I see zero depiction of "flow" up through that orifice that you've shown....and the air in that image, that is in front of the air box "louvers"...it looks pretty stagnant to me. What I don't see is that "cold air" rushing in to the area in front of the filter. Again, you think that image proves your point, your comments about it differ from Aardwolf's and I think the image backs up my point. I guess we're interpreting the image differently.
I don't know what we're looking at here. A black pic of a blurry light. Is that the same pic as your first pic, only back lit? Try to answer that, if you could, minus the insult. That would be great, thanks.
Originally Posted by Aardwolf
Years back there was a thread with more of these pics:
As far as I know the air is from the from leaking around the fog lights, hood gap, etc. The pic shows no airflow backwards to the filter.
I mean...what I'm seeing there is a hot air intake. What I see is the vast majority of the cold air in that picture is going through the radiator.
I feel that pic proves my point....bow tie and moto man feel that it proves theirs. Time to whip out the meter.
Old Jun 1, 2016 | 12:41 AM
  #47
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Semantics. Useless talking around the issue again...
I sure am off the rails asking you for the same evidence you require (and ignore) from me.
Say what? Giving my analysis of the photos is "semantics"? How are my thoughts about the photos any more "semantical" than yours?? they're both opinions of an image. Volunteering to take measurements of underhood temps is "semantics"?? How so?
Old Jun 1, 2016 | 12:56 AM
  #48
bow tie guy
No Tom semantics of arguing a point that was made befor Aardwolf explained it to you in plain english
lets refresh: the IAT's were data logged @ 1 dergree above ambient
not 30 not 40 and certainly not 50
and it doesen't take a rhodes scholar to distinguish "Hot under hood air" from the "semi sealed under hood area" to ambient does it ?
Old Jun 1, 2016 | 01:30 AM
  #49
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Look Aardwolf posted his data, for his '88. I posted mine, for my '92. YOU latched onto his and are claiming it as gospel, apparently. *I* am interested in BOTH. Who has the open mind? Who is exploring the facts here?
"Semi sealed under hood area" isn't COLD air induction. What you get is a "semi mixed" bunch of air. Some air may well be (probably is) "cold"/ambient air...some is warm/hot air from the engine, exhaust manifold, radiator etc. So is it a HOT air intake? I guess maybe not, b/c it's not drawing air off the exhaust manifold directly...but it's not what I would call a cold air intake either. A Cold air induction system very deliberately segregates outside air from any under hood air. I don't think anyone can claim that the C4 intake does that, with a straight face. Temp testing will show what is really going on. And maybe you're right; Maybe the filter area is so meticulously designed that even though it's wide open...and in the "under hood area"...maybe only ambient air magically makes it into that space and into the air filter w/o mixing w/any of that other under hood air. Maybe on an 80* day, your air temps at the louvers is 80*. Maybe...but I doubt it.
Old Jun 1, 2016 | 01:39 AM
  #50
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
So we have our definitions clear, to me, this is a true, "cold air intake", because it cannot possibly draw any air from the under hood area "Semi sealed" or otherwise. The opening for the air filter housing is physically outside the engine bay, sitting, literally, in ambient air.
Old Jun 1, 2016 | 01:55 AM
  #51
bow tie guy
never mind Aardwolf go look under your bowling green emblem
those louvers are behind an opening in the bumper reinforcement
Old Jun 1, 2016 | 02:06 AM
  #52
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
So whats your point
That the C4, doesn't have a cold air intake. I thought I was clear about that, but I guess I wasn't.
Old Jun 1, 2016 | 02:12 AM
  #53
bow tie guy
Well it certainly hasn't a Hot one, I was clear about that
Old Jun 1, 2016 | 02:23 AM
  #54
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You were clear that was your opinion, yes. I didn't see you produce anything meaningful to support your thinking, however. What I mostly saw was insults, when challenged.
Guys, the image is of a C6. This is why, I choose to fact find, rather than throw insults.
So should we agree to call the thing a "Tepid Air intake"?
Old Jun 1, 2016 | 02:33 AM
  #55
bow tie guy
84Z51J
If you're trolling, consider me trolled. All I do is present evidence, facts, and an explanation of why this system works the way it does based on the laws of physics...all you do is wear me down and declare those facts false, with no evidence to support your own claims, and utter refusal to grant me an inch.
As far as I'm concerned Tom your opinion of meaningful makes no matter
Old Jun 1, 2016 | 03:31 AM
  #56
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't doubt it. Interesting though...no comment on the C6 image?
Why do you keep quoting 84Z51?
I'll post up my temp results when I have time to record them.
Old Jun 1, 2016 | 04:23 AM
  #57
exitwound's Avatar
exitwound
I did all these and my '87 is much livelier than it was...
cut open the air box
fit an itg filter
descreen the maf
bypass the tb coolant
relocate the mat sensor
160deg thermostat
AIR delete
A/C delete
new Taylor ignition system
refurbed the entire fuel system
tb airofoil
made my fpr adjustable to give 45psi
straight 60mm pipes all the way out the back
10deg intial timing
lost about 150lbs of dead weight
1.5-ve camber and about 8deg +ve caster
Some of this stuff is controversial, but maybe it all needs to work together to get any benefit. It drives much better than it ever did and still gets good mpg and decent handling. Yes I know there's lots of 4 bangers that are faster, but they don't come with a healthy V8 soundtrack and that's what I like best.
To Performance Upgrades
Old Jun 1, 2016 | 05:05 AM
  #58
crowz's Avatar
crowz
Dollar for dollar if you really want more power just save up your money and replace the engine....
Back in the day I tried about every tweak I could on the stock motor. The only thing that made a difference was a supercharger on my 86.
Dollar for dollar the 383 stroker in my 87 convertible would smoke the stock motor with the supercharger my 86 had.
All the non expensive tweaks I did on the 86 wouldn't even shave a full second off the 1/4 miles times.
Old Jun 1, 2016 | 05:19 AM
  #59
crowz's Avatar
crowz
As for the cold air intake part I think this pic another member posted about an hour ago in another thread shows how the air gets in. Looks like a cold air intake to me.
Old Jun 1, 2016 | 06:06 AM
  #60
PatternDayTrader
Well if the image is from a c6 car then it cant be applied to the c4. Intake air temp sensor data will be conclusive. Tepid air is sort of the goal from the designers point of view. Its not supposed to be a forced air intake or the risk of water entering the airbox would be too high. At least for a street car. I could see where it would still draw from air that is basically outside (the engine compartment) air temp anyway. Just like the mustang you posted the photo of that has the inlet in the inner fender cavity.
So what is it your planning tom ? Are you going to put a thermometer in the air box somehow ? That would be pretty conclusive, although I tend to believe the IAT sensor data.
