I have a few small questions regarding the 95 C4 before buying some parts on line.
What's the difference between a 95 C4 Coupe & Hatchback?? Asked by Vendor
How can I tell if I have a HD suspension or STD suspension before ordering Brake Parts? Asked by Vendor
Can I install 13" Rotors on my 95 C4 Base Coupe?? The factory Rotors are 12"????
Thanks for the help in advance :-)
You mentioned '95 so it could be assumed that unless someone had changed things the car would have 13" rotors as "standard" with the 12" option going away in that year. Measure to confirm!!
I'd also suggest "LOCAL PARTS PURCHASES!!!
Oh good to know 13" are standard. I will measure before purchasing.
If you have 255's front and 285's rear, it's safe to say you have the base suspension. But look under the center console. If HD suspension, it'll say ZO7.
The 13" brake option is J55. It was optional from '88 -'94 while the base was a 12" rotor. The 13" was standard on '95-'96.
The bigger brakes were required/or part of several suspension options like the Z51 from '88 -'94. Because they were part of the suspension options, some parts places call it the HD suspension option even for brakes. This does not apply for '95-'96 since all of them have the big brakes (13").
