1994 console/bezel replacement
Old May 31, 2016 | 08:36 AM
LINUS STEW's Avatar
LINUS STEW
Cruising
Default 1994 console/bezel replacement
I am replacing the shift console bezel and cannot figure out how to get the lighter socket and rear hatch button out of the old one. Can someone give me some direction here?
Old May 31, 2016 | 08:31 PM
SB96CE's Avatar
SB96CE
They must be removed from the bottom side of the console and pushed through the top. From underneath, the backing socket of the lighter is threaded. It should take a very light twist counter clockwise to remove.. For the rear hatch, there are two little spring tabs with two arms each that need to be pushed in. Push them in gently and wiggle it out the top.
Old Jun 1, 2016 | 08:11 AM
LINUS STEW's Avatar
LINUS STEW
Cruising
Originally Posted by SB96CE
The must be removed from the bottom side of the console and pushed through the top. From underneath, the backing socket of the lighter is threaded. It should take a very light twist counter clockwise to remove.. For the rear hatch, there are two little spring tabs with two arms each that need to be pushed in. Push them in gently and wiggle it out the top.
Thaanks here! I will try this.
To 1994 console/bezel replacement
