Plugs
Old Jun 3, 2016 | 05:03 PM
monte k's Avatar
monte k
Default Plugs
I have a Stock,, 1984 5.7 Tpi,
What's the recommended plugs for this engine
Monte K
Old Jun 3, 2016 | 05:29 PM
PatternDayTrader's Avatar
PatternDayTrader
I don't know. Probably the cr43ts, but I wouldn't use it anyway. Instead, figure out which platinum tip plug is the direct replacement and use those.
Old Jun 3, 2016 | 10:30 PM
aklim's Avatar
aklim
I toss my plugs every year so I don't really get those 4 prong platinum ones.
Old Jun 3, 2016 | 10:35 PM
PatternDayTrader
Your making work for yourself ...
Old Jun 3, 2016 | 10:51 PM
aklim's Avatar
aklim
I change cap and rotor every year because of the boogers hanging off the electrodes. At which time, I like to peek into the cylinders and make sure all is well and the plugs don't stick. I run the cap and rotor till spring and change it for the new season. Plugs seem to be able to last about 2 years max before I get hiccups which the new plugs instantly cure with the long life ones. Besides, with the TPIS headers, they are pretty easy to change
Old Mar 20, 2023 | 02:15 PM
AZSP33D's Avatar
AZSP33D
Be careful the early heads had a much different spark plug than the later heads (shorter). For brands I recommend Champion and AC Delco copper plugs, no platinum, and Iridium is a waste on a normally aspirated engine.
To Plugs
