engine compatment cleaning
Old Sep 8, 2002 | 05:09 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default engine compatment cleaning
with the motor out of my 93 i fugured it was a good time to give the engine compartment a thorough cleaning, but don't want to mees anything up, anyone done this???????
Old Sep 8, 2002 | 05:14 PM
vader86's Avatar
vader86
Default Re: engine compatment cleaning (vetteman9368)
get some simple green and a toothbrush, small spray bottle to wet things
just dont get the opti wet
Old Sep 8, 2002 | 05:20 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Engine OUT of the car???? Nope! But i'll bet the same rules apply! Keep the opti dry. A lit'l Simple Green and a LOT of rags, brushes and elbow grease! ;)
So far as the engine COMPARTMENT goes...i'd think that dang near ANYTHING goes! (i'd still shy away from the pressure washing though...)
Old Sep 8, 2002 | 05:37 PM
red-y's Avatar
red-y
Default Re: engine compatment cleaning (Alchemist)
Simple Green on the engine and whatever on the compartment.
Just replaced Opti, if you have over 50k on the Opti it may be a good time to change it - :smash:
Old Sep 8, 2002 | 05:41 PM
vetteman9368
St. Jude Donor '08
Default Re: engine compatment cleaning (red-y)
well considering the only thing i am re using is the block, and intake, shouldn't be a problem, thanx for the advice, i'll try some simple green
To engine compatment cleaning
