a/c possible leak
Old Jun 5, 2016 | 04:58 AM
scrappy76's Avatar
scrappy76
Default a/c possible leak
Recently I went and try to recharge my a/c system on my 92 lt1. well it filled up fine and the a/c became nice and cool. Well the next morning I went to use it and it was warm again, so I figured I had a leak. Visually looking at everything I noticed on the high pressure line on the passenger side going into the firewall, there is a plug connector with wires going into a plug mounted to the metal a/c hose. it is damp and so is the hose directly under it and the other things. I am thinking this is the a/c refrigerant switch. Am I correct ?
Old Jun 5, 2016 | 06:19 AM
PatternDayTrader's Avatar
PatternDayTrader
If its mounted on the line itself then it must be. If it will empty itself overnight then you should be able to find the leak using soap and water. Like you were looking for a nail hole in a tire, watch for the bubbles .... At least then you will know for certain.
Old Jun 5, 2016 | 06:44 AM
hcbph's Avatar
hcbph
Check with a black light, if they used dyed Freon in charging the system, you'll see telltale remnant of it under a black light.
Old Jun 5, 2016 | 11:43 PM
aklim's Avatar
aklim
Did you run a vacuum on it to see if it holds vacuum? What was the pressure when you pumped in refrigerant? Are you sure you sealed it properly when you changed the receiver dryer?
Old Jun 6, 2016 | 05:46 AM
scrappy76's Avatar
scrappy76
I did not run a vacuum test. The pressure was in the good. I am not sure what you mean did I seal after I changed the receiver dryer ?
All the fittings were tight. I am pretty sure it leaked out at the pressure switch. It was not damp/shiny in that area last time I looked. I bought a can of a/c charge that includes dye. I do need to find a blacklight so I can be sure. I will get a new switch and change that first before I try it again, The refrigerant is too expensive to waste.
Old Jun 6, 2016 | 09:30 AM
PatternDayTrader
Originally Posted by scrappy76
I bought a can of a/c charge that includes dye. .
In the future, I would try and avoid any refrigerant that has additives such as dye or sealer.
Old Jun 6, 2016 | 10:00 AM
scrappy76's Avatar
scrappy76
I have not used it yet, I can take it back, but can you explain why ?
Old Jun 6, 2016 | 10:16 AM
antfarmer2's Avatar
antfarmer2
Just crap that does not need to be in there get a cheap sniffer off ebay or harbour freight. I got one for less than $20.
Old Jun 6, 2016 | 11:18 AM
aklim's Avatar
aklim
I don't follow. Why exactly would you recharge it if the pressure was good? If it wasn't, you should have used a sniffer to check around for leaks before going to full pressure. Once you find the leak, evacuate the system, fix the leak and change the receiver dryer which you should do once you open up the system. After that, draw a vacuum and make sure it holds. Then pressurize the system with refrigerant and add dye
Old Jun 6, 2016 | 11:21 AM
PatternDayTrader
Well first never use anything that included sealer. No matter what. Ive seen that stuff screw up the orifice tube more than once.
Dye is less of a problem but its neither refrigerant or oil, unfortunately it displaces both. So one can with dye is ok but if you find yourself in a spot where you add a can per year (like many of us do) then it should be straight refrigerant. Don't even continue to add refrigerant with oil in it. You have to keep in mind that small leaks will only allow the refrigerant gas to escape, the oil and dye and everything else will remain, so it can really accumulate in the system over time.
Old Jun 6, 2016 | 11:22 AM
PatternDayTrader
Why would you replace the dryer ?? especially if you evacuate the system w a vacuum pump ??
Old Jun 6, 2016 | 11:33 AM
aklim's Avatar
aklim
Because it's cheap enough
https://macsworldwide.wordpress.com/...ars-ac-system/
Receiver/driers serve three very important functions:
They act as a temporary storage containers for oil and refrigerant when neither are needed for system operation (such as during periods of low cooling demand). This is the “receiver” function of the receiver/drier.
Most receiver/driers contain a filter that can trap debris that may be inside the A/C system.
Receiver/driers contain a material called desiccant. The desiccant is used to absorb moisture (water) that may have gotten inside the A/C system during manufacture, assembly or service. Moisture can get into the A/C components from humidity in the air. This is the “drier” function of the receiver/drier.
Damage can occur if there’s excessive moisture inside an A/C system. It can cause corrosion, as well as possibly degrade the performance of the compressor’s lubricating oil.
The receiver/drier should be replaced any time the system is opened for service, and most compressor warranties require it. The desiccant is only capable of absorbing a certain amount of moisture, and when the inside of the system and/or the receiver/drier are exposed to the atmosphere, the desiccant can become very quickly saturated from humidity in the air. If this occurs, the desiccant is no longer effective, and will not provide future protection. Additionally, the filter inside the receiver/drier could be restricted by debris that may have been inside the system. This could diminish refrigerant and oil flow.
Old Jun 6, 2016 | 11:48 AM
PatternDayTrader
I can accept the inexpensive economics as a valid answer. I can accept a compressor failure and debris in the system also. As far as the desiccant and water contamination; well I see that as nonsense spewing forth from those selling ac parts and service.
H2O boils at 53 degrees Fahrenheit when contained in a vacuum of 29.5 in of mercury. This means if you draw a proper vacuum, then you will evacuate all the water vapor. Believe it or not, water boils at -24 degrees F at 29.91in of mercury, although your vacuum pump probably wont achieve that number.
Old Jun 6, 2016 | 12:03 PM
aklim's Avatar
aklim
All that is nice but it doesn't tell if the desiccant can be "recharged" by vacuum. If it absorbs a finite amount of water and that is that, we have one scenario. If it absorbs till saturated but can be dried out and absorb more water, we have another case.
According to a guy HERE
The short answer is NO.
You don't have enough vacuum, even with the two stage pump. You would need the turbo pump to remove the moisture from the desiccant. The molecular sieve desiccant will release water when the partial pressure of water vapor above the desiccant is lower than the partial pressure of moisture inside the desiccant. To reactivate the desiccant you would need to reduce the pressure to less than 10 microns for as long as it takes for the water to migrate out of the sieve (hours / days?). The recommended procedure from UOP (who makes the sieve) to regenerate the desiccant is to heat to 600 degrees F and pass dry nitrogen through the drier for four hours. If you overheat the sieve, you will destroy the crystalline structure of the sieve and ruin it.
Buy a new drier and toss the old one in the garbage.
Maybe he is wrong but for $40, do you really want to chance it? I don't
Old Jun 6, 2016 | 12:36 PM
PatternDayTrader
Again i could support the idea based on the economics, but its not necessary based on need.
I don't buy the idea of needing to reduce the h2o to 10 microns in an effort to restore the desiccant either. The guy you quoted even said "the molecular sieve desiccant will release water when the partial pressure of water vapor above the desiccant is lower than the partial pressure of moisture inside the desiccant". At the very best he has made some conflicting statements.
Whatever tho ... Go ahead are replace your drier, after all they are very inexpensive.
Old Jun 7, 2016 | 11:19 AM
scrappy76's Avatar
scrappy76
You guys are really amazing how much knowledge you have and its a much needed thing sometimes. I feel like pulling up a recliner with a tall glass of tea and a fattie and just take it all in.
My a/c needed a recharge. I vacuumed it out and bought refrigerant. There was no pressure. I filled the system till the gauge was in the good. The a/c was nice and cool. I shut the car off put all my tools away and went inside for the evening. The next day in the afternoon, I went for a drive to the store and turned on the a/c. nothing but warm air came out. I popped the hood to see if I could see anything. I check all the connection and the ports, everything was tight and looked dull, till I noticed the pressure switch in the high pressure line going to the dash. It has an oilish shine on it and below it. it wasn't there before. I have a gut feeling that is where my leak is. the silicone like seal around the pressure switch came off when I wiped the switch off. I found a new one for $30 and I am going to replace it.
I have recharged a/c in about a dozen cars I have owned with great results and never replaced the dryer. Thank you for the advise but for now, I will not replace this one either.
Old Jun 7, 2016 | 02:05 PM
PatternDayTrader
Well I wish I could be there for that !
Old Jun 13, 2016 | 06:14 AM
scrappy76's Avatar
scrappy76
UPDATE.
The new sensor came in and I installed it, I recharged the system on Saturday morning. Everything nice and cool. Yesterday afternoon I went for a drive and the a/c was still blowing cold. So It looks as if I have fixed this leak. We will see how it goes.
Old Jul 19, 2016 | 08:44 AM
Renfield's Avatar
Renfield
Is there a common spot for leaks on the C4? One or two specific spots that fail? I'm going to check that switch on my '95. It has the same symptoms (i.e. filled and gone in a day).
Aklim, it's not like you to waste ANY amount on an unscientific and absolutely necessary solution. Where are the double blind tests, the control groups, the expert bloggers from the University of Phoenix?!?
Somewhere the Guidions may be missing a bible.
I'll second (third?) that fattie.
To a/c possible leak
