95 Steering Noise
Old Jun 7, 2016 | 06:21 AM
tmirisola's Avatar
tmirisola
Default 95 Steering Noise
I am getting an awful low growl whine noise when the car has been driven for a while (hot) when driving/cornering at slow speeds around 10mph. The steering wheel will need be to be turned from 50% to all the way for cornering or during U-turn to make the noise.
The steering wheel/turning does not get difficult during the noise.
I cannot make the noise without the car rolling. Turning the steering wheel while at a stand still will not reproduce the noise.
Car has 18k on the clock and the steering fluid is full.
Any suggestions/help is appreciated
Old Jun 7, 2016 | 06:28 AM
TorchTarga94's Avatar
TorchTarga94
Have you tried using turkey baster to remove old fluid and put in new?
Old Jun 7, 2016 | 06:30 AM
PatternDayTrader's Avatar
PatternDayTrader
Dry tie rod ends and ball joints can make an awful sound when turning ...
Old Jun 7, 2016 | 06:36 AM
tmirisola's Avatar
tmirisola
No. How is the fluid replaced/changed???? Never did this before.
Old Jun 7, 2016 | 06:37 AM
tmirisola's Avatar
tmirisola
The noise is engine driven.
Old Jun 7, 2016 | 06:42 AM
TorchTarga94
Use a turkey baster to remove all the fluid you can from the power steering reservoir. Then refill with same amount of new fluid. If you have no history of it ever being done it is an easy and inexpensive thing to rule out.
Old Jun 7, 2016 | 06:48 AM
tmirisola's Avatar
tmirisola
Should I replace with Synthetic fluid?? Or, Regular Fluid??? Recommended fluid for 95????
Old Jun 7, 2016 | 07:05 AM
TorchTarga94
It looks like you are participating in an active power steering fluid thread:
https://www.corvetteforum.com/forums...post1592358213
Go with synthetic if you can. However, Lucas worked well for me, makes things a little more quiet as well.
Old Jun 7, 2016 | 07:17 AM
tmirisola's Avatar
tmirisola
Yes But, still not decided what is best. Thank you for your help. Much appreciated
I will go with the Synthetic. Must buy a new Turkey Baster today rather than get beat with the one in her drawer :-)
Old Jun 7, 2016 | 07:28 AM
exitwound's Avatar
exitwound
I use this as 100% in my '87 and have done problem free for over ten years...
http://lucasoil.com/products/problem...ring-stop-leak
Its like ATF, but a little thicker. Great stuff!
To 95 Steering Noise
