Wheel Balancing Weights
Old Sep 8, 2002 | 10:42 PM
RDRUNR's Avatar
RDRUNR
Default Wheel Balancing Weights
I'm having my wheels balanced this week and was wondering if I should put weights on both sides or only on the inside. Shouldn't thay be able to balance them using the weights on the inside only instead of putting those ugly weights on the outside and screwing up the finish? By the way the shop I am going to has a Hunter 9700 Road Force balancer. Any opinions
Old Sep 8, 2002 | 10:53 PM
bac22's Avatar
bac22
Default Re: Wheel Balancing Weights (RDRUNR)
You can put weights on the inside only. A decent tire shop should have no problem doing this.
Old Sep 8, 2002 | 11:48 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Wheel Balancing Weights (bac22)
Yep mine are all inside, they use weights that stick w/ some sort of adhesive backing.
Old Sep 8, 2002 | 11:51 PM
GDP's Avatar
GDP
You will develop a shimmy in your wheel if you don't have it balanced from the outside and inside. :smash:
EDIT: The shimmy will be at speeds of 75-80+ MPH
[Modified by GDP, 9:52 PM 9/8/2002]
To Wheel Balancing Weights
