AC compressor turns kinda hard and also seizes after warmed up during hot weather. Anyone here ever rebuild a compressor? I found the bearings I need(I think)pretty cheap and figured it may be an easy job to tackle.
If your are thinking about internal compressor repairs not simple normally requiring special tools. You won't know what you got until it's apart. The front clutch and pulley assembly is serviceable. It does require a puller / installer and there should be a video. Normally if it's seizing; there is an internal failure and time for new compressor. You could try some kinda a/c miracle treatment that fixes everything first. I have no favorite to recommend.
