Trans problem still present...
Old Sep 9, 2002 | 12:01 PM
Bravery's Avatar
Bravery
Default Trans problem still present...
Had the transmission fluid and filter changed two weeks ago. Trans temperature has dropped to a reasonable 185-200 degrees on normal driving (no traffic). At various times, under WOT, the trans will still hit the rev limiter on shifts. It is not a continuous problem as it will act up on one run then I do it again and it shifts fine. Traction control is turned off.
Thoughts?
Mike
Old Sep 9, 2002 | 11:45 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Trans problem still present... (Bravery)
Maybe Mr. Mojo will move this over to tech for you. Those guys know everything. :seeya
