Vehicle Speed Sensor
Old Jun 20, 2016 | 12:19 PM
Jeffeory's Avatar
Jeffeory
3rd Gear
Default Vehicle Speed Sensor
I have a 1990 Corvette ZF6, my Vehicle Speed Sensor came apart and was leaking through the center around the plug. After many hours of research I've found that GM doesn't make a replacement part for my car and no reproductinons were made either. I've exhausted the salvage yard search through the country and there all gone from existing transmissions. Is there any alternative different sensor and change computer or anything. This is what happens when you get Germany involved.
Old Jun 20, 2016 | 01:27 PM
WVZR-1's Avatar
WVZR-1
I supplied a part# in your PARTS WTB post earlier. This post is timed well after that so I'm guessing you've seen it. If you check the tooth count that I mentioned in that post compared to what's on your VSS and the tooth count in car - you should be all set.
A search for 10456089 should get you all of the info you need.
Old Jun 21, 2016 | 08:28 AM
Jeffeory's Avatar
Jeffeory
3rd Gear
Thanks for the info my car is 42 tooth with 4000 pulses per mile I'm now going to look for the 10456089 part #, The chevy gararge gave me the part #'s 25007308 for a 3.07, 3.33, & 3.45 with 25007273 for a 2.59 & 2.73. I've really struggled with this fix not liking working on my 68-427. I did see your post yesterday but didn't realize these were timed so thanks for the follow up.
To Vehicle Speed Sensor
